| Forum topic by ND2ELK | posted 137 days ago | 457 views | 0 times favorited | 13 replies | ![]() |
137 days ago |
I finally decided what other equipment I am going to buy for my shop. I also came up with a layout for the shop. I would appriciate your thoughts and comments on both. The shop is only 14’ X 21’ which will require the equipment to be mobile. I need to make a miter saw counter on the west wall of the shop along with a catch/assembly table with storage below for power hand tools that will sit in front of the table saw on the east wall. If you go to finewoodworking.com and look at the article Dead-Flat Assembly Table, you can see what it will look like. There will be an upper storage cabinet on the west wall and under the table saw extention table. On the back north wall is a built in storage cabinet where my air compressor sits, dust cyclone, filter canesters and small metal tool box. On the east wall is peg boards to hang my hand tools on. Once the counter and storage cabinets are built I can start buying the rest of the equipment. There is a 8’ X 10’ storage shed out the back door for jigs, off fall and wood storage. The only pieces of equipment I have bought so far is : PM2000 table saw, Makita 12” sliding miter saw and a Makita air compressor. All the drills, routers, sanders, saws, nailers, stapler, biscuit cutter and dovetail jig are bought. The equipment I am planning on buying : Jet 14DXPRO 14” Deluxe Bandsaw, PM2800 18” Variable Drill Press, Woodtek 2HP Reversible two speed Shaper, PM54A 6” Jointer, Makita 201NB 12” Planer, Jet 16-32 Drum Sander, PM701 Bench Top Mortiser, Ridgid EB4424 Spindle/Edge Sander and the Jet Scissor Lift Table. I plan on building skid platforms for the mortiser, planer, spindle/edge sander, drum sander and store them under the counter. I will use the scissor lift table to move them out and raise them to the desired height I want. The scissor lift table can also be used to help support sheet stock being cut on the table saw. If you go to my workshop you can see the floor plan. Thanks for looking! -- Mc Bridge Cabinets, Iowa |
