How small does a piece of wood need to be before it is too small to keep?
« back to Coffee Lounge forum
Forum topic by Vincent Nocito posted 137 days ago 439 views 0 times favorited 23 replies Add to Favorites Watch
View Vincent Nocito's profile
Vincent Nocito
158 posts in 262 days
137 days ago
Topic tags/keywords: question
I suspect that this is a problem that many of us suffer from….”How small does a piece of wood need to be before it is too small to keep?” My shop is awash in small cut off that I have saved for years….never know when you might need a small piece for a glue block or something. I am currently in the middle of a major clean up and was wondering, what criteria do you use to decide that a piece of wood is just too small. Jim Tolpin recommends a piece must be larger than 2” x 2 feet and sheet goods should be at least 2 square feel. What does everybody else use as a guideline.
17022 posts in 475 days
137 days ago
Hey Vince
I guess it depends on what you make. some guys make pens out of of dozens of pieces of wood half the size of a pencil erasers.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
Vincent Nocito
137 days ago
I don’t turn so the smallest thing that I build would be a jewelry box. Mostly, I build furniture.
View SteveB's profile
SteveB
51 posts in 956 days
137 days ago
The smallest lumber I’ve seen was my dad’s stock of balsa—1/8” x 1/8”
-- Steve B - New Life Home Improvement
View John 's profile
John
110 posts in 300 days
137 days ago
I usually have a couple of 5 gal buckets laying around with a bunch of falloff but then they get full, and I throw something in the burn can. THAT”S WHEN I NEED IT. Always works that way.
John
-- http://www.webshots.com/user/jahness
View woodisit's profile
woodisit
61 posts in 139 days
137 days ago
I am one of those people that try to keep everything, the hard part is keeping them organized so you can find them when you need them! The larger pcs I put on selves the small pcs I put in a 3×3 box.
-- Woodisit
View GaryK's profile
GaryK
9537 posts in 886 days
137 days ago
It depends on what you make. If you only make furniture get rid of or give away your smaller pieces.
View scrappy's profile
scrappy
1653 posts in 328 days
137 days ago
I make allmost EVERYTHING from SCRAP! What most of you throw away it what I go buy to start a project! So….it is ALL kept. It is almost dust before I get rid of it.
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
TopamaxSurvivor
3063 posts in 574 days
137 days ago
I saw a listiing for a plane on ebay that said it was from the estate of some pack rats. They even kept the wood shavings ;-)) I don’t go that far, but I keep a lot of small blocks, I’m always looking for one for something and I never seem to have many. Not sure what I do with them ???
View dustbunny's profile
dustbunny
330 posts in 193 days
136 days ago
If it floats it the air….it’s too small, LOL.
What I am thinking is that you can always cut a sliver or small piece off any larger piece. So if it is less than 2” get rid of it.
-- I inherited the woodworking gene and it's gone into overdrive.......
View snowdog's profile
snowdog
808 posts in 880 days
136 days ago
Everything burns, so I keep most of it until I need to make a fire then a lot of it gets used :)
scrappy
136 days ago
Hey TopmaxSurvivor, What were those shavings? I made a couple of candle holders out of arromatic cedar and when I drilled the holes for the tea lights my wife was gathering up the shavings from the padle bit for potpuree!
Got them in containers setting around the house now. Can’t even get rid of dust i guess. haha
TopamaxSurvivor
136 days ago
Scrappy, It didn’t say, but I thought about the Woodright making a plane to cut long curls to light pipes:-))
View mmh's profile
mmh
1395 posts in 620 days
136 days ago
Throw away? Why would you want to throw ANY of it away? I have buckets of cut offs and scraps. Guess I need to start composting them along with the sawdust. But then again, you could fill your matress with the curly soft shavings . . .
TopamaxSurvivor
136 days ago
If you can’t make a tooth pick, it should go! :-))
View Joe Lyddon's profile
Joe Lyddon
486 posts in 950 days
128 days ago
How small is the smallest Knob you would want to make?
View PurpLev's profile
PurpLev
2763 posts in 546 days
128 days ago
this subject is posted here every once in a while… I can’t remember who said it in the last thread with this topic – but it was good:
if it doesn’t fit in the 2 1/2” shopvac hose – it stays!
7670 posts in 1116 days
128 days ago
I have the same problem. I tend to save most everything that I can imagine ever being useful for something. I do frequently draw from these small cutoffs, but they still seem to accumulate faster than I use them.
As much as I hate to do it, when the supply gets out of hand I just throw a bunch away. As a matter a fact, I left a couple cardboard boxes full at the curb this morning.
View sIKE's profile
sIKE
1094 posts in 652 days
128 days ago
I have developed a new system this year. I keep any hardwood I am inclinded I want. Then right before my camping trip I go through all of it and throw what I no longer want/need/had too long into a bin and it is then used to start my campfires and roast marshmallows….. :)
View Greg's profile
Greg
225 posts in 206 days
128 days ago
I soak all scrap pieces in water and use them in my barbecue pit. Ever had cocobolo or walnut smoked ribeye? Yummy!
-- Each and Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Greg Little
View DonDA's profile
DonDA
24 posts in 129 days
128 days ago
Same problem – never want to throw any pieces away. Just started milling for a cherry amoire and already have a bunch of “pieces” that I think should go but just can’t part with. When the wife wants to start a fire in the fireplace this winter I’ll volunteer some pieces to help get it started.
-- Don, Saginaw Mi
25806 posts in 1298 days
128 days ago
My small hardwoods Oak, maple, walnut, cherry becomes smoke wood for the BBQ.
View Kent Shepherd's profile
Kent Shepherd
839 posts in 184 days
121 days ago
I basically only keep small pieces of exotics, and then I keep almost everything. I produce way too much of more common hardwoods to be worth the storage. I’m working on a jig right now to route curves on pieces about 1 1/4×1 1/4”, 3/8” thick.
I also save a lot of cherry and hickory for smoking meat. ( I almost just said for smoking, but realized the comments I might get!!!)
Quite a few people raid my dumpster for scraps. I’m always glad someone can make use of my waste.
View BeachedBones's profile
BeachedBones
187 posts in 300 days
121 days ago
Too small for me is anything that can be sucked up by the shop vac, or thinner than a pencil.
-- You know.... I think that old wood needs to be furniture.
