Best Joint for Glass Cabinet Doors
« back to Joinery forum
Forum topic by coachjohnson posted 04-09-2015 05:02 PM 895 views 0 times favorited 4 replies Add to Favorites Watch
View coachjohnson's profile
24 posts in 2261 days
04-09-2015 05:02 PM
Topic tags/keywords: question oak
What’s the easiest, quickest, and strongest joint to use when building glass doors for a set of cabinets? They are rather tall, around 50 inches and about 18 inches wide. The lower cabinet doors were constructed using grooves and stub tenons, but they only house a 1/4 piece of plywood.
-- Lack of planning on your part does not constitute an emergency on my part.
View bondogaposis's profile
4629 posts in 2280 days
#1 posted 04-09-2015 06:06 PM
M & T.
-- Bondo Gaposis
View AlaskaGuy's profile
3968 posts in 2238 days
#2 posted 04-09-2015 06:34 PM
There are 3 joints that would work. The choice would be what you are best set up to do or have experience with.
Half Lap
Bridle Joint
Another consideration is how wide you style and rails are. The wider the more glue surface.
View BinghamtonEd's profile
2286 posts in 2298 days
#3 posted 04-09-2015 07:15 PM
I’d go with M&T, they will visually match the existing doors and will be very strong. Rabbet the back and, after the glass is in, nail in strips to hold it secure.
View gfadvm's profile
14940 posts in 2619 days
#4 posted 04-10-2015 12:11 AM
Any of the above suggestions will work but I’m partial to half laps: strong, self squaring, and EASY to make.
