Drywall Fittings
Forum topic by EdsCustomWoodCrafts posted 04-09-2015 04:29 PM 817 views 0 times favorited 5 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
840 posts in 1486 days
04-09-2015 04:29 PM
I am in the planning stages of designing a Zig Zag corner shelf unit pictured below and I am attaching it to drywall I don’t really want to use a cleat system but I’m wondering if anyone can recommend a drywall fitting the only thing is I’m not sure what the weight is
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
5 replies so far
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1320 days
#1 posted 04-09-2015 04:35 PM
You will need to consider the weight of the shelves themselves plus the weight of what is on the shelves.
Is this a single unit or is each shelf separate?
Assuming that you don’t want screws showing the two methods that come to mind are:
1. recessed screws and plugs
2. key holes
3. construction adhesive
method #1 has the problem of color matching the plug
method #2 has the problem of alignment of all of the key holes.
EdsCustomWoodCrafts
#2 posted 04-09-2015 04:40 PM
I am in the planning stages of designing a Zig Zag corner shelf unit pictured below and I am attaching it to drywall I don t really want to use a cleat system but I m wondering if anyone can recommend a drywall fitting the only thing is I m not sure what the weight is
Assuming that you don t want screws showing the two methods that come to mind are:
2. key holes
- WoodNSawdust
2. key holes
- WoodNSawdust
2. key holes
- WoodNSawdust
2. key holes
- WoodNSawdust
Yes it is one unit and I’m not concerned about mounting screws showing
MrUnix
6925 posts in 2342 days
#3 posted 04-09-2015 04:41 PM
Screws and plugs would support the most weight. You can screw directly into the studs in the corners, and use twist-n-lock drywall screw anchors on the outboard edges which are great little buggers and will hold quite a bit of weight. Since you haven’t built it yet, getting the plugs to match should not be a problem.
EdsCustomWoodCrafts
#4 posted 04-09-2015 05:25 PM
Screws and plugs would support the most weight. You can screw directly into the studs in the corners, and use twist-n-lock drywall screw anchors on the outboard edges which are great little buggers and will hold quite a bit of weight. Since you haven t built it yet, getting the plugs to match should not be a problem.
If I may ask should there be studs right in the corners and on the Home Depot site does the 50lb weight refer to each drywall screw? Or the entire pack.. Sorry I’m not used to ganging stuff I guess
- MrUnix
View greg48's profile
greg48
610 posts in 2901 days
#5 posted 04-09-2015 07:29 PM
I’ll go with Brad (MrUnix). Get yourself a plug cutter bit and cut your own plugs out of your project material for a near perfect color and grain match.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
