| Forum topic by jake36 | posted 139 days ago | 362 views | 1 time favorited | 10 replies | ![]() |
139 days ago |
I THINK that somewhere I have seen a formula which will allow me to make a staved cylinder of a certain diameter. I cannot seem to find it anywhere. If any of you know where I might find and copy this information I would sure appreciate it. I am trying to make some birdhouses for Christmas. jake1936@bellsouth.net Jake -- Jake Caldwell |
139 days ago |
you take the number of staves you want to use and diviide it into 360, then take that number to get the degree of angle you need to cut, for example, I use twelve sides for alot of my segmented turnings, you would take 360 divided by 12=30 degrees, divide that by 2 which equals 15, that is the number of degrees that you need to set your saw for. An improtant thing to remember is that the fewer sides the more forgiving the tolerances, the more pieces the greater chance that even being off a fraction of a degree can add up fast to being off by several degrees at the end. -- barlow |
139 days ago |
I did a little searching and couldn’t find anything so I decided to try to figure it out. Disclaimer: I have only tested this on paper and I’m no mathematician but here’s what I came up with. Use with care! d = diameter of vessel d • sin(180/n) = s For example if you want a 4 inch diameter vessel with 12 staves each stave would be: -- Dan |
139 days ago |
pi x R (radius) squared will give you the circumference. 3.14×4 = 12.56 / 12 = 1.04” Looks like ignoring that .035” in the trig calc is going to leave you about 1/2” short on the circumference. :-)) I doubt if the birds will ever know, As long as the staves are cut with the correct bevel, it will still come out. -- Debt is nothing more than the 21st Century's form of slavery. |
139 days ago |
Bob.. Pi R squared equals area.. for the circumference.. it is 2 x Pi x R -- Drink once, cut twice. New website up.... lazylarrywoodworks.com.au |
139 days ago |
You’re right!! :-(( Guess I’d better use pi x Diameter, eh? :-)) I wonder why the 2 calcs are .14” off? -- Debt is nothing more than the 21st Century's form of slavery. |
131 days ago |
Thanks for all your help. Barlow seems to have one I can understand. Jake -- Jake Caldwell |
131 days ago |
Sorry I couldn’t miss the opportunity for a little pun The roundest knight at King Arthur’s round table was Sir Cumference. He acquired his size from too much pi. -- Its never too late to have a happy childhood. But the second one is up to you and no one else. |
131 days ago |
I’ve used this reference for a couple of items – which pretty much says what Barlow did http://www.woodmagazine.com/woodworking-tips/techniques/intermediate/staves-and-segments/ -- Woodworking.....My small slice of heaven! |
131 days ago |
That ’s a handly little table, Thanks. -- Debt is nothing more than the 21st Century's form of slavery. |
130 days ago |
Gota thank you Reggick this is solving all my problems. Be sure to take your flea meds. Its a hot summer. J -- Jake Caldwell |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
