Custom Router Bit
Forum topic by oldreddog posted 04-09-2015 11:10 AM 1010 views 0 times favorited 9 replies Add to Favorites Watch
View oldreddog's profile
oldreddog
165 posts in 2574 days
04-09-2015 11:10 AM
Topic tags/keywords: question
I am looking to get a custom router bit made for a 28 degree angle with a guide bearing.
Have any of you fellow LJ’s had a similar job done if so what was your expense and experience ? thanks …...
-- oldreddog
9 replies so far
View rick1955's profile
rick1955
264 posts in 1672 days
#1 posted 04-09-2015 11:37 AM
Very expensive. Over $200. Give more details and a picture and there may be options. Always give more details as what you want isn’t always what you need.
-- Working smarter with less tools is a true crafts person...
TheWoodenOyster
1317 posts in 2176 days
#2 posted 04-09-2015 12:38 PM
I bet whiteside would make it, but much money it will cost.
-- The Wood Is Your Oyster
View hotbyte's profile
hotbyte
991 posts in 3216 days
#3 posted 04-09-2015 01:26 PM
Can you make a wedge shaped base plate and use a straight bit to achieve desired angle? Or, a hinged base plate that adjust to angles similar to setup for a circular saw bevel cut.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2610 days
#4 posted 04-09-2015 01:35 PM
- hotbyte
That was my thought, too. What’s this going to be used for? Is it a big production run, or a one-off or hobby thing? If the latter, might be easier/cheaper to bring the bit to 28 degrees, than buy a 28-degree bit.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1257 posts in 1954 days
#5 posted 04-09-2015 01:39 PM
For serious work buy/borrow/steal one of these with a guide bushing on a shaper.
-- "Do or Do not. There is no try." - Yoda
kaerlighedsbamsen
#6 posted 04-09-2015 01:44 PM
Or get access to one of these grinders with a diamond cutter and reshape an exisiting router. Easy!
View SirIrb's profile
SirIrb
1239 posts in 1471 days
#7 posted 04-09-2015 02:19 PM
that is one of the sexiest things i have seen for a shaper.
- kaerlighedsbamsen
oldreddog
#8 posted 04-09-2015 06:22 PM
Thanks everyone for the great ideas , I love that adjustable shaper head, might just grab that for kicks.. But I found a company here in the midwest that will custom make that bit for 158.00 bucks
1/2 inch shank 26 degree pattern bit for my router table.
They are drawing up a shop detail drawing now.
10-15 days until delivery.
I will be using this for custom lamp shades for the side bevel.
It takes the table saw out of that part of the project and makes building these lamps just that much safer.
-- oldreddog
oldreddog
#9 posted 04-09-2015 06:31 PM
here was a little sketch sent them, I can’t quite figure out that photo bucket site yet , it cuts off half my images , but I know you catch the drift.
Heres a link to the company. Made right here in the USA which I love.
Thanks again..
http://www.carbidespecialties.com/About_us.htm
-- oldreddog
