Drop leaf extension hardware
« back to Coffee Lounge forum
Forum topic by sanfranciscocedarco posted 04-09-2015 12:04 AM 1655 views 0 times favorited 6 replies Add to Favorites Watch
View sanfranciscocedarco's profile
sanfranciscocedarco
48 posts in 1545 days
04-09-2015 12:04 AM
Topic tags/keywords: resource tip question oak drill-driver chisel router clamp carving milling shaping rustic
I’m Building a few tables that will have a fold under extension. I want the extension to be hidden underneath. This is for a restaurant so I don’t want people banging their legs into it. I ordered a kit that supports the extension and then retracts and supports it while it’s folded up but it won’t work for mine because my extension is 18”. The biggest size they had was 9” Any ideas for a hardware solution?? I’ll post the kit I have. I like the design, it’s perfect but I need it twice as big. Also its a pedestal base and no aprons, That’s why I haven’t just used another method.
-- J.D. Goldberg, California, http:www.jdgoldbergfurnitureco.com
View waho6o9's profile
waho6o9
8240 posts in 2630 days
#1 posted 04-09-2015 12:35 AM
http://www.leevalley.com/US/Hardware/page.aspx?p=40143&cat=3,43586
Not sure if this is what you’re looking for, in any event Lee Valley offers other
items as well.
Good luck now.
sanfranciscocedarco
#2 posted 04-09-2015 12:37 AM
How have I not seen those!. Ur a lifesaver. Thanks so much!
View NoThanks's profile
NoThanks
798 posts in 1582 days
#3 posted 04-09-2015 12:48 AM
I don’t think they are heavy duty enough for an 18” extension. Guess it depends on how heavy the extension is.
Do a test first before you commit…
Be carefull when you get them, them tricky bast**ds will snap your fingers if your not careful. Don’t ask how I know this…
-- Because I'm gone, that's why!
waho6o9
#4 posted 04-09-2015 01:18 AM
You’re welcome J.D.Goldberg! Glad I could help.
sanfranciscocedarco
#5 posted 04-09-2015 02:43 AM
Well it says they can support up to 88 lbs each. I’ll have room to install two on the one leaf. I’m thinking it will be ok.
NoThanks
#6 posted 04-09-2015 04:25 AM
Well it says they can support up to 88 lbs each. I ll have room to install two on the one leaf. I m thinking it will be ok.
- sanfranciscocedarco
But it also says 12” maximum. at 18” there is a lot more leverage.
I’m not saying they won’t work,
but in a commercial setting I would rather have overkill than underkill, if you know what I mean.
It makes you look bad if you have to go back and replace them with something else.
I would test them before you commit to a design using them.
I’ve used them before, just trying to help.
