Staining Red Oak in Texas
Forum topic by ChasHutch posted 07-13-2009 04:45 PM 1477 views 0 times favorited 5 replies Add to Favorites Watch
View ChasHutch's profile
ChasHutch
56 posts in 3685 days
07-13-2009 04:45 PM
Topic tags/keywords: oak finishing question
Hi LJ’s
Was hoping someone could suggest a fix for this? I have built a mission style headboard for a customer and am in the finishing process. The stain is pushing out of the pours in little droplets.
Stain bubbles on red oak
I have stained furniture with red oak before and have not had this much problem. Here is what I have done so far.
- Environmentals: I am finishing early in the morning (7:00 am) when the temprature is between 85 & 90 degrees but the humidity is around 70-80%. The temps have been over 100 for the past few weeks and I need to deliver this ASAP so I can not wait for October for the Dallas weather to change.
I have applied:
- 2 coats of wash (25% sanding sealer/75% laquer thinner) light sand between coats
- two coats of stain sanding between coats
I am spraying the finish with an HVLP gun. The stain can not sit long or it is like trying to wipe off glue.
I suspect the temprature and humidty may be the issue. Do I need a blush retarder in the stain?
Any thoughts would be appreciated.
Hutch
-- Hutch - North Dallas, Tx - Safety First
5 replies so far
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3256 days
#1 posted 07-13-2009 09:37 PM
I’ve not had this problem before. What type of stain are you using? Did you let the stain dry completely before you sealed it? I sometimes have trouble if I don’t, but am not sure about this problem. I guess it could be the humidity—-I wouln’t know. I live in Lubbock where we don’t get much rain. I doubt that retarder would help. I’ve never heard of using it for stain.I often use it for lacquer though. (It does rain occasionally)
-- http://shepherdtoolandsupply.com/
Kent Shepherd
#2 posted 07-13-2009 11:10 PM
Sorry—hit the wrong thing
117063 posts in 3547 days
#3 posted 07-15-2009 04:43 PM
Hey Hutch
This is a typical problem with red oak usually with oil base stains. This is a case for watching the finish after applied , if you apply your finish and go to bed and find it in the morning it means sanding it down and more stain, but if you catch it when it happen you just wipe the excess away.
ChasHutch
#4 posted 07-20-2009 07:00 PM
Thanks Jim.. I appreciate the response. I have sanded the spots and am getting ready to re-stain (which is fine because it still needed more stain). I have the feeling that I will just babysit it and keep wiping the spots.
Hutch
ChasHutch
#5 posted 07-20-2009 07:00 PM
Hutch
