Is there an easy way to adjust countertop height?
Forum topic by mcg1990 posted 04-08-2015 09:21 PM 1407 views 0 times favorited 17 replies Add to Favorites Watch
View mcg1990's profile
mcg1990
159 posts in 1526 days
04-08-2015 09:21 PM
I’ve spent the last couple of days building some base cabinets for the shop, but sadly they’re not level due to being built on sloppily poured concrete (also my fault).
As you can probably deduce; I’m recessing my mitre saw into the tabletop. The plan is to eventually have all kinds of T-tracks and stuff going on, but right now I just need a good level tabletop.
The top is made out of two 3/4” sheets of ply laminated together. As the top is >8’ long I’ve had to make it in parts, so although SketchUp doesn’t show it, the mitre saw recess actually extends to the back of the bench and the table is split in two. They’re both independent from each other.
But now I get to laying the tops on the cabinets I find that they’re not level. With themselves or with each other.
Is there any hardware in existence that are essentially adjustable mounting brackets for cabinet tops? Something that I can get underneath and tweak with a screwdriver to adjust the level.
Thanks
17 replies so far
View johnstoneb's profile
johnstoneb
3070 posts in 2406 days
#1 posted 04-08-2015 09:32 PM
Kitchen cabinets are shimmed at the floor until they are level and lined up. No floor is ever totally level.
-- Bruce, Boise, ID
mcg1990
#2 posted 04-08-2015 09:34 PM
Aye, sadly these are the first cabinets I’ve built though, and I’ve made sure that I can’t do anything like that.. I think I have to tackle the problem at the countertop itself.
So far all I can think of is using levelling feet to get it where I want it, then use L-brackets to secure it in place. Does anyone else have a more elegant solution?
View Troy Cleckler 's profile
Troy Cleckler
385 posts in 1605 days
#3 posted 04-08-2015 09:35 PM
Shim cabinets at the floor and screw them together and to the wall. Solid top and less likely to warp.
-- Troy. - Measure twice, cut once and fill the gaps....
View canadianchips's profile
canadianchips
2615 posts in 3230 days
#4 posted 04-08-2015 11:57 PM
As johnstoneb and Troy said. Shim them at the base. Any other readjusting is going to look crooked and be weaker. Thats just how it is done !
View crank49's profile
crank49
4032 posts in 3204 days
#5 posted 04-09-2015 12:10 AM
Are they (the base cabinets) anchored to the floor and/or wall?
If they are, you might have to do what you were talking about; adjust the mounting of the top.
Otherwise, I’d be shimming the bottom; even if I had to remove a bunch of screws in the back.
If you absolutely have to adjust at the top, perhaps you can install a level, co-planar, apron on top of the inside perimeter of the base frame. Then set the top on this apron and trim the gap or fill it with something.
View Ghidrah's profile
Ghidrah
667 posts in 1456 days
#6 posted 04-09-2015 01:05 AM
If it’s the kick area your worried about you can always cut a façade. In new construction cabs are often installed prior to the und. layment so the shims are hidden. On older homes the house has had yrs or decades to settle/go mental, so if the und lay is already there a thin façade can be applied to cover the gaps.
-- I meant to do that!
View waho6o9's profile
waho6o9
8539 posts in 2810 days
#7 posted 04-09-2015 01:15 AM
All concrete has a slope for drainage.
Build a big ol rectangular box and make it level where you want your cabinets.
Fasten to the concrete, lay ply on top and then secure your cabinets to the ply
and the wall and your done.
mcg1990
#8 posted 04-09-2015 01:40 AM
I’ll do my best to shim the box that I built the cabinets on, but if I do have to end up shimming/finding hardware to adjust the top, can anyone suggest any products or rigs?
View MT_Stringer's profile
MT_Stringer
3183 posts in 3464 days
#9 posted 04-09-2015 01:43 AM
If it is not too late, build a ladder frame. Level it and anchor to the wall. Then place your cabinets on top and screw them together.
There is a lot more info in my blog that details our kitchen remodel.
http://lumberjocks.com/MT_Stringer/blog/42062
Good luck.
Mike
View jak77's profile
jak77
18 posts in 2175 days
#10 posted 04-09-2015 01:52 AM
Never fasten cabinets on two planes. Houses move. Enough movement will tear apart your cabinets.
Assemble flat boxes across the top. The top will be completely supported this way. Shim the boxes at the floor or use adjustable legs and then scribe the kick to fit the floor.
View joey502's profile
joey502
544 posts in 1751 days
#11 posted 04-09-2015 10:44 AM
Can you shim in between the cabinet and the top itself?
Do you have a picture of the cabinets you can post?
Is the unit one long cabinet or smaller cabinets joined together?
View rwe2156's profile
rwe2156
3225 posts in 1714 days
#12 posted 04-09-2015 11:47 AM
What does this mean? Are you cabinets not all the same height?
Are they separate units?
If not, how did you build them?
Either way, leg levelers will solve your issue.
Scribe the toe kick to the floor and you’ll be good to go.
I used these.
If you can’t do that, then you can scab a cleat to the sides and level them off.
View SirIrb's profile
SirIrb
1239 posts in 1464 days
#13 posted 04-09-2015 12:07 PM
As stated above: dont tweak the tops, tweak the cabinets. Even if you have a huge gap at the bottom you can run base over it and hide it. But everything therein will always be dead level like the bottoms of drawers.
View Ken 's profile
Ken
21 posts in 1461 days
#14 posted 04-11-2015 05:51 AM
Cabinet maker showed me years ago how he does it. Lay the cabinets on their back. Line up the tops. Screw the sides of the cabinets together. Now as one big assembly, stand them up. Screw to the wall. Shim the base. Cover the gaps. And don’t use the old wood shims. Get the engineered wood shims as they will not compress with age.
View skatefriday's profile
skatefriday
439 posts in 1716 days
#15 posted 04-11-2015 03:00 PM
Bob Lang recommends building separate bases, lay the base down, shim it level
and then place the cabinet on top of the base. The base forms the toe kick area.
I’ve made four cabinets that way so far. None of them are installed yet.
I’ll let you know how it goes. :-)
