Toy box for the youngster - couple questions
Forum topic by AAANDRRREW posted 04-08-2015 02:05 PM 1021 views 0 times favorited 8 replies Add to Favorites Watch
View AAANDRRREW's profile
AAANDRRREW
210 posts in 1346 days
04-08-2015 02:05 PM
I found some plans for a cool toy box for my 2 year old I’d like to build. It was off of a site called rogue engineer.
I do have a few questions… it calls for the box portion to by plywood (which I’m fine with) but they call it sandply. What is sandply? I usually go to Menards for my wood (I also have a HD here). I’ve gotten the 5 green stripe nicer construction plywood and the double sided oak plywood for projects, but not sure what this sandply is.
Also, at the corners of the box, they don’t use any trim or solid wood to hide the ply endgrain – I’d like to make it look a little neater than that. I am guessing if I bevel the verticle edges to make a 45 the veneer would chip out and it’d look poor, right? The only thing I can think of other than filling the edge and painting it (or using edge banding) is to have a 1×1 or something be the corner piece and have the ply butt up to that on both sides of the corner.
heres a link to the project. Doesn’t have to be anything exotic – he’s 2 and it will likely take one heck of a beating through the years. :)
http://rogueengineer.com/free-hope-chest-plans/
8 replies so far
View Julian's profile
Julian
1388 posts in 2864 days
#1 posted 04-08-2015 02:58 PM
Never heard the term “sandply”. Just use a good quality plywood. I wouldn’t leave the edges exposed because it will easily chip. Take a look on YouTube (Jon Peters Arts & Home); he built a plywood toy chest and has a very clever way to cover the exposed plywood edges. He has about 3-4 videos showing the build process. Plus, it is a very nice looking chest.
-- Julian
View RRBOU's profile
RRBOU
176 posts in 2466 days
#2 posted 04-08-2015 03:03 PM
Sandply is a Home Depot product. It is what HD calls cabinet grade.
http://www.homedepot.com/p/Unbranded-Sande-Plywood-Common-1-2-in-x-4-ft-x-8-ft-Actual-0-472-in-x-48-in-x-96-in-454532/100017950?MERCH=REC-_-nosearch2_rr-_-NA-_-100017950-_-N
-- If guns cause crime all of mine are defective Randy
View Redoak49's profile
Redoak49
3596 posts in 2162 days
#3 posted 04-08-2015 03:21 PM
Menards has a sanded plywood product that I have used. My kids are grow and with kids of their own.
I built several toy boxes for them. They were about 16 wide , 24 long and 12 tall. I built them out of the glued up pine that you can get from Menards. The corners were dovetails and I put carpet style casters on the bottom. I also attached a short 3/4” rope to pull it with. The bottom was inset and 1/2 ” plywood.
The toy boxes survived everything the kids did to them including riding in them as another pulled them…the boxes are now with the grand kids except two with toy in my house for when they visit. The boxes are easy to move around and have the kids put toys back in them. It is never too early to have them learn to pick up their toys.
I did not put a lid on them but would be easy to do.
Redoak49
#4 posted 04-08-2015 03:24 PM
I stained and then finished with poly and they have a well used look to them. It makes me smile when the grand kids are digging thru them for toys
AAANDRRREW
#5 posted 04-08-2015 05:47 PM
redoak – glued up pine – are you talking plywood or something different?
Redoak49
#6 posted 04-08-2015 08:43 PM
Menards has wide pine made up of narrower pieces edge glued…it is not plywood. It is very stable and does not warp. Sorry, I should have been more clear.
View Kazooman's profile
Kazooman
1214 posts in 2126 days
#7 posted 04-08-2015 09:17 PM
I can’t imagine just butting the ends of two pieces of plywood to make a box. That has to be about the weakest joint possible. Butting the end of the ply up to a corner post isn’t a whole lot better. A slightly beefier corner piece with dados for the plywood would make a much stronger box and give it a much nicer finished look.
View Jim Finn's profile
Jim Finn
2684 posts in 3096 days
#8 posted 04-09-2015 12:43 AM
If you put a lid on it you should install a slow closing device to avoid smashed fingers. Also when closed, air should be able to get in there in case a child gets inside and goes to sleep. This is a common occurrence. This is the last one I made.
-- No PHD just a DD214 Website> craftingcouple.com
