Disassembly of Delta Milwaukee CBL402 Tailstock (1640 Lathe)
Forum topic by Jeff C posted 04-08-2015 03:21 AM 1618 views 0 times favorited 7 replies Add to Favorites Watch
View Jeff C's profile
Jeff C
6 posts in 1169 days
04-08-2015 03:21 AM
Topic tags/keywords: delta 1460 cbl402 tailstock
I have scoured the threads and cannot find exactly what I am looking for:
Just purchased a Delta Milwaukee 1460 Lathe – cannot date because the bed is a welded set of channels – however, head and tailstock are both marked. Tailstock is CBL402 and is “old style”.
Here’s the question: How do I remove the cap that sits in front of the ball cap? I have the diagram but cannot tell if it is threaded or a press fit? I would like to know before I screw anything up :). BTW, have already replaced the headstock bearings and have a VFD motor coming!
Pic of cap attached
-- Jeff C, Wylie, TX
7 replies so far
View MrUnix's profile
MrUnix
6698 posts in 2193 days
#1 posted 04-08-2015 03:30 AM
It unscrews… remove the crank handle first and then use a vice to get it off. Note – It’s a right hand thread! Wrap with leather or something similar to keep it from getting buggered up (see instructions). Here are some instructions for performing a tailstock mod that includes disassembly instructions:
http://vintagemachinery.org/pubs/1141/2369.pdf
PS: I’ve never seen a Delta lathe (or any for that matter) where the end cap was a press fit… all are either threaded or held in with spring pins or clips of some sort.
View Wildwood's profile
Wildwood
2305 posts in 2129 days
#2 posted 04-08-2015 11:25 AM
Nice info and save Brad! Would squirt some oil or penetraing fluid first?
-- Bill
Jeff C
#3 posted 04-08-2015 12:55 PM
Brad – thanks much – the pdf is more detailed than others I had found – dang nice to know it is RH thread, otherwise I might have been up a creek! Bill, I have been squirting a little WD-40 every few days before I go removing anything. If it is still tight, I’ll step it up a notch.
View Bluepine38's profile
Bluepine38
3379 posts in 3079 days
#4 posted 04-08-2015 04:09 PM
Thank you for the info MrUnix, I did not have that in the file on my lathe, now I will go out and try this
out.
View JoeinGa's profile
JoeinGa
7736 posts in 2001 days
#5 posted 04-09-2015 12:18 AM
THIS stuff is WAY better than WD40. Every shop should have a can. You can buy it at the big box stores, auto supply house, and I think even WallyWorld has it.
Jeff C
#6 posted 04-09-2015 12:19 AM
Brad – ended up having to put it in vice (protected, of course), but a few gentle taps using the mass of the body and the threads easily disengaged.
MrUnix
#7 posted 04-09-2015 12:44 AM
- jcourtma
Good deal! They usually aren’t too difficult to get off since they should only be hand tight, but sometimes you gotta give it a little more persuasion due to age and rust/corrosion.
