How hot should a jigsaw get?
Forum topic by spaids posted 07-12-2009 03:35 PM 5443 views 0 times favorited 6 replies Add to Favorites Watch
View spaids's profile
spaids
699 posts in 3655 days
07-12-2009 03:35 PM
Topic tags/keywords: jig saw
I just bought a Bosch barrell grip jig saw off of Amazon. I tried it out on some 3/4 ply and I am very pleased with the saw. It is smooth and the cuts are very nice. My quesiton is, after only about 5 minutes of using the jigsaw it was pretty darn hot. Is this normal?
Amazon
-- Wipe the blood stains from your blade before coming in.--
View TomHintz's profile
TomHintz
207 posts in 3360 days
#1 posted 07-12-2009 03:49 PM
I have tried a bunch of jigsaws for reviews over the years and they all get what I consider very hot around the front end. I talked to factory reps at a few shows and they all said the same thing – that there is lots going on in there and those cases have considerable amounts of lubricant that transfers lots of heat to the cover.
I have a Bosch barrel grip that I have use extensively for a couple years now and it runs perfect today. It does get hot but that has not bothered it a bit.
-- Tom Hintz, www.newwoodworker.com
View Chris Wright's profile
Chris Wright
540 posts in 3443 days
#2 posted 07-12-2009 03:55 PM
All tools are going to generate heat after extended use. My Festool sander gets pretty warm when I’m running it for a bit. As long as it’s not so hot that it burns you, I think you’re pretty safe.
-- "At its best, life is completely unpredictable." - Christopher Walken
13600 posts in 3303 days
#3 posted 07-12-2009 03:56 PM
i got a barrel grip too ,
make sure your blades are good for the work/wood and sharp ,
as a rule
warm enough to keep your coffee warm ,
cold enough not to burn your toast .
View cabinetmaster's profile
cabinetmaster
10874 posts in 3520 days
#4 posted 07-12-2009 03:58 PM
I’ve noticed the same thing with jigsaws. But I’m like Chris. If it’s not hot enough to burn you it should be OK.
spaids
#5 posted 07-12-2009 08:34 PM
Hey guys thanks a lot! I am very happy with the new saw and really did not want to hear that it was defective. Isn’t lumberjocks awesome. I have an issue Sunday morning and I have 4 answers by the time I get home from church. sweet.
View michaelk's profile
michaelk
1 post in 3194 days
#6 posted 07-21-2009 04:57 PM
I have quite a few electronic components, like the bosh jigsaw, and it is quite common that these do get warm. It is quite a comforting feeling, once you got used to it, as it tells you how smoking hot your work is.
