Need some ideas...
Forum topic by DKV posted 04-07-2015 11:21 PM 1542 views 0 times favorited 14 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2738 days
04-07-2015 11:21 PM
Whenever I use my router table without my fence and the attached dust collection my shop looks like a snow storm hit. The router blows everything straight up. Are there any jigs I can build or buy that will capture the dust? How do you guys handle it? Thanks for the help.
-- This is a Troll Free zone.
14 replies so far
View waho6o9's profile
waho6o9
8539 posts in 2810 days
#1 posted 04-07-2015 11:50 PM
https://www.youtube.com/watch?v=wu2IRr3VK5I
Incra has a viable solution.
View Ghidrah's profile
Ghidrah
667 posts in 1456 days
#2 posted 04-08-2015 12:05 AM
my table/cabinet also vacuums from below
-- I meant to do that!
View Picklehead's profile
Picklehead
1053 posts in 2163 days
#3 posted 04-08-2015 01:37 AM
Articulated over-arm hoovermebobber:
https://www.youtube.com/watch?v=OiArfLkrNlM
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
View jacquesr's profile
jacquesr
345 posts in 1657 days
#4 posted 04-08-2015 02:18 AM
I have the Incra CleanSweep. No more dust. Period. Especially with the Super System and in-fence dust capture. Cleanest tool in my small shop.
View DKV's profile
DKV
#5 posted 04-08-2015 02:21 AM
Thanks, Picklehead. My router puts gale force winds out through the throat of my router table and when routing without my fence/dust collection I get sawdust all over. I need something above the router bit to catch the tornado of dust as it heads for the ceiling and I think something similar to your suggestion would work perfect. Maybe a plastic Homedepot bucket with the dust collection attached to the bottom side. It either gets sucked up or stopped and dropped.
View webe1959's profile
webe1959
4 posts in 1404 days
#6 posted 04-08-2015 02:23 AM
I have dust collection through the cabinet that controls most of that issue. I also built a downdraft table that comes in great for pieces that don’t fit on the router table and for sanding as well.
-- Bill's Dog House.....
View MT_Stringer's profile
MT_Stringer
3183 posts in 3465 days
#7 posted 04-08-2015 02:24 AM
What model is your router?
View timbertailor's profile
timbertailor
1594 posts in 1658 days
#8 posted 04-08-2015 02:30 AM
Build your own box to enclose the router from below.
View DKV's profile
DKV
#9 posted 04-08-2015 02:32 AM
MT, I have the Dewalt DW618.
MT_Stringer
#10 posted 04-08-2015 03:03 AM
- DKV
It should be similar to my Bosch 1617 or the Triton 3 1/4 hp router. I hook up a hose under the table to the router dust port. And a second one to the fence if I am using it. It even helps to let the fence set nearby if it won’t be used, yet still suck a little.
Regardless, sometimes, the chips simply fly. :-(
View DKV's profile
DKV
#11 posted 04-08-2015 07:53 AM
In the past I used my router table for two reasons. 1. To do profiles. In this instance with the bit buried halfway in the fence and the dust collection mounted to the fence I get very little dust. 2. To do dados. In this instance all of the dust is shot out the left side of the table from under the board. 3. To do dovetails with my new Gifkin jig. Without the fence all of the dust shoots into the air (my face as I lean over the jig to do the cuts) and coats the entire local area.
I used to mount a box under my router but found there was very little of any sawdust or chips to collect. I’m pretty sure all routers take air in at the top (by the switch) and shoot it out the bottom. Makes sense since air out the bottom clears dust from around the router bit. When we take a router and turn it upside down to mount in a router lift we now have the air blowing up and out. This is the problem I’m encountering. I never free handed on the router table until now. I really think a funnel or bucket hung over the table throat with a hose attached will help with the problem. I will follow up after trying my idea.
Now, if I could figure out how to upload pictures…Did someone change something?
View robscastle's profile
robscastle
5626 posts in 2438 days
#12 posted 05-31-2015 10:59 PM
Put the hose into the other port on your Dust collection/vacuum
Turn the power onto the Dust collection/vacuum when using the router
Fit a metal shield around the collet mounted firmly to the router base
-- Regards Rob
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#13 posted 06-01-2015 12:26 AM
I don’t think suspending a bucket above the table will work due to gravity. A wedge shaped hood connected to your shop vac will probably be a better fix. Don’t attach it to the table. Just set it where it is most needed.
View BroncoBrian's profile
BroncoBrian
875 posts in 2192 days
#14 posted 06-02-2015 10:19 PM
- jacquesr
Good to know. I have one in the box that I have not taken the time to install yet. Will do this weekend. Pretty impressed with their stuff and the video was convincing so I bought it.
Do you use their $50 insert pack?
-- A severed foot is the ultimate stocking stuffer.
