Souped up my ROS
Forum topic by JoeinGa posted 04-07-2015 09:37 PM 1351 views 0 times favorited 16 replies Add to Favorites Watch
View JoeinGa's profile
JoeinGa
7739 posts in 2241 days
04-07-2015 09:37 PM
I have 2 random orbit sanders. Both of them have the vents just above the sanding disc where the fan discharge blows out. Since I’m right handed if I want to sand the edge of a board or maybe I’m sanding the right side of something that’s too big to turn on it’s side what I do is simply rotate the ROS over on it’s side and sand away.
Now I dont know if any of you do this, but every time I do, that air discharge tends to blow sanding dust in my face which I dislike immensely. So I added a little “duct work” to my sanders which re-directs that air stream. Now, no more dust in my face.
Yeah, yeah, I know. Some of you use a shop vac hose connected to the dust port on yours, but I just dont LIKE using that hose. It just seems to always be in the way or getting hung up on the edge of my bench. So this was my solution. I cut a small piece of sheet metal, about the size (and shape) of my thumb. Hammered it into a sort of spoon shape, and attached it with some of my racing duct tape. Works like a charm.
16 replies so far
View mahdee's profile
mahdee
4041 posts in 2002 days
#1 posted 04-08-2015 01:21 AM
Good idea… My drill does the same thing. I’ll have to see if I can divert that air elsewhere.
-- earthartandfoods.com
View CypressAndPine's profile
CypressAndPine
62 posts in 2041 days
#2 posted 04-08-2015 01:27 AM
It probably won’t happen, but make sure your motor doesn’t get too hot. You may have decreased the cooling effect on the coils.
Regards,
Jacob
-- Cypress Jake, New Orleans
View doubleDD's profile
doubleDD
8036 posts in 2277 days
#3 posted 04-08-2015 02:19 AM
Good idea Joe. I know what you mean when you get blasted from it. Let us know if it runs the same with the diversion.
JoeinGa
#4 posted 04-08-2015 12:07 PM
Thanks guys.
Jake, thanks for pointing that out. I dont have a way to scientifically do this but I did TRY to test the air flow by letting it blow in my face with nothing covering the port, and then about 5 times during the changes I made in this little project.
I started out with a flat piece of metal and duct tape, which blocked almost ALL the exhaust from that one port. I was worried (as you pointed out) that it might overheat the tool. I also tried drilling holes in the piece of metal (which basically defeated the whole idea at all)
Then it was just a matter of coming up with a shape that might work. I tried several versions of bending the deflector, both horizontally and vertically. Neither did much good. Then I noticed a spoon on my bench and I cut the handle off it, which made me realize I was onto the solution. Since I couldn’t bend the spoon very easily, it was just a matter od shaping my sheet metal into some sort of spoon-shape and then fitting the duct tape around it.
This last version seems to blow just as much air at my face as the sander did with no deflector on it. And the shape is curved somewhat front to back so the air blows more “around” the tool, rather than straight out from that port. Now when I hold the sander is on it’s side, the sir blows away from me and no longer straight up at my face.
View Jim Finn's profile
Jim Finn
2688 posts in 3156 days
#5 posted 04-08-2015 12:50 PM
I taped over one of the air discharge slots on my drill for this same reason. Works great.
-- No PHD just a DD214 Website> craftingcouple.com
View Ghidrah's profile
Ghidrah
667 posts in 1456 days
#6 posted 04-08-2015 03:47 PM
I’m sure you already tried it and weren’t satisfied, but in case not, while not perfect, I have and use a 1 1/4” hose and run it over my shoulder.
-- I meant to do that!
View grantd's profile
grantd
88 posts in 1717 days
#7 posted 04-08-2015 03:49 PM
The racing tape should make it spin faster too, right?
View redSLED's profile
redSLED
790 posts in 2127 days
#8 posted 04-09-2015 03:58 PM
Very nice.
That custom ‘SPOONED PORT’ (you heard it here first) with the checkered tape looks to be a ‘winning’ solution.
View knotscott's profile
knotscott
8172 posts in 3610 days
#9 posted 04-09-2015 04:02 PM
Congrats on taking the checkered flag!
JoeinGa
#10 posted 04-09-2015 04:17 PM
Thanks. I’ve been using all morning and it is working just as I had hoped it would.
I think “Racing Tape” just caps it off :-)
redSLED
#11 posted 04-09-2015 04:20 PM
I might try adding a SPOONED PORT to my Makita belt sander for the same benefit.
JoeinGa
#12 posted 04-09-2015 04:23 PM
Hmm, I also have a Makita belt sander.
Sayyyy Do I need to COPYRIGHT this whole “Spooned port” idea??? :-)
redSLED
#13 posted 04-09-2015 04:28 PM
You mean patent. You would be more successful in making pigs fly.
JoeinGa
#14 posted 04-09-2015 04:58 PM
Details, details! :-)
Oh and…
View distrbd's profile
distrbd
2252 posts in 2681 days
#15 posted 04-09-2015 07:47 PM
I like the pit stop you built for the Dewalt sander.
-- Ken from Ontario, Canada
