Large number of parts organization
Forum topic by jmartel posted 04-07-2015 05:43 PM 1365 views 0 times favorited 17 replies Add to Favorites Watch
View jmartel's profile
jmartel
7687 posts in 2055 days
04-07-2015 05:43 PM
How does everyone else do their parts organization? Especially when talking about large numbers of parts. I’ve got an entertainment center that I’m building that will have around 20 part sizes, with multiples of each part.
In the past I’ve used a pencil to mark it, but over the course of working it, that can go away. And given that I use walnut a lot, it’s difficult to see sometimes. My initial thoughts are to use masking tape with a sharpie on the show face, and a few pieces to mark the forward edge and the top edge/side. Given that some of the pieces are close to square, but one side is slightly longer, I figured marking the sides would prevent confusion from machining the wrong side. Probably use letters to distinguish each part rather than number. My thoughts with the tape is that I can take the tape off if needed, and put it back on after machining that side.
Any other better ways that I’m missing? I know everyone tends to have their own way of organizing things and keeping them in order.
17 replies so far
View timbertailor's profile
timbertailor
1594 posts in 1329 days
#1 posted 04-07-2015 05:56 PM
Painters tape or just right on them in pencil before final sanding.
View shipwright's profile
shipwright
7894 posts in 2703 days
#2 posted 04-07-2015 06:24 PM
View NoThanks's profile
NoThanks
798 posts in 1434 days
#3 posted 04-07-2015 06:35 PM
- shipwright
So what are you saying, Permatex Magic Marker :)
I mark the edges and keep things in piles.
1 dot for shelves, 2 dots for adjustables, FE for finished end panels, Ijmb for center dividers.
I also keep everything face up throughout the build.
-- Because I'm gone, that's why!
View waho6o9's profile
waho6o9
8099 posts in 2482 days
#4 posted 04-07-2015 06:44 PM
Contrasting colors work for me and I like green on walnut easy to see.
jmartel
#5 posted 04-07-2015 07:23 PM
- shipwright
I think for this build, the smallest piece is 15”x18” or something aside from trim, so I think I’ll have more space than you usually do to label.
View bigblockyeti's profile
bigblockyeti
4986 posts in 1626 days
#6 posted 04-07-2015 09:26 PM
As far as keeping things in order for myself while I’m in the middle of making something (especially when dealing with large numbers of similar parts) I like to put parts on shelves. Performing all of a specific machining task on each stack of similar (or identical) parts before moving onto the next stack or next machine helps to make the process flow more efficiently and gives me good stopping points that can be resumed quickly.
View Jim Finn's profile
Jim Finn
2622 posts in 2827 days
#7 posted 04-07-2015 09:33 PM
I have not faced this issue but if I were to… I would mark with masking tape and write on that.
View Bluepine38's profile
Bluepine38
3379 posts in 2990 days
#8 posted 04-09-2015 04:54 PM
83 door and drawer panel custom kitchen, we used numbers and letters on the stiles, rails and panels
where they would not show, throw in the middle stiles on large panels and it got very interesting. It
did however get finished. Used a 1/4” letter/number stamp set to put make the imprint then filled in
with fine lead mechanical pencil.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1480 days
#9 posted 04-09-2015 05:11 PM
zip lock bags for small part and write on them in a way that you can reuse the bags.write on the end grain numbers,timber framers use roman numbers easy to read.
View distrbd's profile
distrbd
2252 posts in 2351 days
#10 posted 04-09-2015 05:20 PM
I use these Stanley small parts organizers,they are stackable and very practical:
-- Ken from Ontario, Canada
View Picklehead's profile
Picklehead
1041 posts in 1834 days
#11 posted 04-12-2015 10:52 AM
- shipwright
Paul, is this a wooly mammoth?
-- You've got to be smarter than the tree.
View lunn's profile
lunn
215 posts in 2214 days
#12 posted 04-12-2015 11:40 AM
I’m with waho The colored pencils won’t scratch wood like lead does. Wipes off with mineral spirits. If your using oil base stain, it will take it off. Tape left on for a long time, may leave glue residue from the tape, especially if it gets damp.
-- What started as a hobbie is now a full time JOB!
View Pezking7p's profile
Pezking7p
3217 posts in 1556 days
#13 posted 04-12-2015 12:22 PM
I used the good 3m masking tape when doing my cabinet build, and make sure to mark the up direction and the show face. I didn’t like the tape technique much, because you had to constantly take it off and put it back. I think pencil on end grain might be best.
-- -Dan
View Woodbum's profile
Woodbum
802 posts in 2970 days
#14 posted 04-12-2015 04:42 PM
Blue painters tape. It releases well and most of the time doesn’t leave residue. But, if you leave it on for a real long time sometimes it doesn’t want to release cleanly. I also mark my parts on the end grain with numbers in chalk, but that can wipe off if used on the flat or the edge of a piece of stock. That’s why I mark on the ends.
-- "Now I'm just another old guy wearing funny clothes"
View CL810's profile
CL810
3730 posts in 2893 days
#15 posted 04-12-2015 07:49 PM
On my cut list I label each piece A, B, C…. Then I mark up the wood with the letters and lines roughly showing the cut lines with chalk. If white chalk won’t show, I use crayons. Then after dimensioning I switch to painters tape and sharpie. Cabinet maker’s triangle for orientation.
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
