door panels
« back to Joinery forum
Forum topic by KellyB posted 04-07-2015 02:53 PM 818 views 0 times favorited 5 replies Add to Favorites Watch
View KellyB's profile
KellyB
77 posts in 1325 days
04-07-2015 02:53 PM
I have a door which will require a panel 12 13/16 in width. I also have two pieces for the panel which are 5 7/8” after milling X2 = 11 3/4” which leaves just a bit over an inch I need to make up.
Given that I can successfully match the face to my satisfaction, is there any reason not to use a 1+ inch strip down the middle?
Thanks.
5 replies so far
View longgone's profile
longgone
5688 posts in 3451 days
#1 posted 04-07-2015 03:05 PM
There is no reason why this would not work. I made 2 frame & panel doors with a contrasting wood center strip in the panel for some end tables and it made for a really nice appearance …
View joey502's profile
joey502
544 posts in 1661 days
#2 posted 04-07-2015 03:23 PM
There is no reason not to add the strip, it will be fine.
KellyB
#3 posted 04-07-2015 04:00 PM
Whew! thank you.
I couldn’t think why it would be a problem, but I have thought that before with notsogood results.
Onward!
View NoThanks's profile
NoThanks
798 posts in 1672 days
#4 posted 04-07-2015 06:27 PM
Without knowing what type of wood,
and you saying your happy with the face match, all is good.
Personally though, depending on wood type, color, where it’s going etc. etc…
I might consider adding 1/2” to both sides.
I don’t care, myself, for having the 1” strip down the middle.
-- Because I'm gone, that's why!
View bigblockyeti's profile (online now)
bigblockyeti
5222 posts in 1864 days
#5 posted 04-07-2015 06:57 PM
If you can match it, go for it, there’s no mechanical disadvantage being created.
