Plane Lapping
Forum topic by Teem posted 140 days ago 249 views 1 time favorited 5 replies Add to Favorites Watch
View Teem's profile
Teem
18 posts in 140 days
140 days ago
What do you use to lap your plane beds? I’ve been messing around with spray adhesive, wet dry sand paper, and a long piece of melamine as a backer, and I get decent results.
-- Friday nights are for high stakes glue ups sucka!
20784 posts in 721 days
140 days ago
Very similar to you, Teem, I use sandpaper with spray adhesive on a 1/4 inch sheet of plate glass with several grits attached.
View Moai's profile
Moai
721 posts in 292 days
140 days ago
Konrad Sauer from Sauer and Steiner practices a VERY accurate and interesting method.
He first uses a marble slab with a paper he found to be the best after trying a bunch of other papers, it’s from NORTON intended for the Body-Auto shop industry: Champagne A285
He recently added a STARRET Machinist granite reference surface for the final stages.
For detailed information visit his blog at sauerandsteiner.com
-- Francisco Luna, San Francisco Bay Area.
View Kent Shepherd's profile
Kent Shepherd
840 posts in 185 days
140 days ago
Same as Scott
View Roper's profile
Roper
761 posts in 612 days
140 days ago
i use a marble slab that was a cut off from a counter top we installed, i also use spray adhesive with norton sandpaper. works great for me.
-- Roper - Master of sawdust-
17115 posts in 476 days
140 days ago
It all works as long as you have a very flat surface and some good sandpaper. I have used glass and aluminum plate
