Grizzly Planer Rollers on Dewalt? Weird snipe issues
Forum topic by Scott C. posted 04-06-2015 09:52 PM 705 views 0 times favorited 1 reply Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 2049 days
04-06-2015 09:52 PM
Anyone know if g0505 rollers (part # P0505040A) will fit in a Dewalt dw733? The parts diagrams look almost identical, and I know a lot of these machines are built in the same factories with some shared parts. The Grizzly parts are quite a bit cheaper when combined with some other items I might order from them. Shot in the dark but figured I throw it out there.
I’m getting some pretty significant 2-stage snipe. The first 2-3 inches is deep and leaves a very visible line when it stops, but then there’s another 5 inches or so of very gradual snipe, like it slopes up to the correct thickness and levels out from there. It’s like this on the front of the board, but not really the back (the back is more typical snipe, deep and obvious, no gradual slope). The front roller is fairly beat up, but the back is still smooth and in good shape. The roller bushings don’t seem any play, although I couldn’t take them out for fear of striping the screws holding the roller bracket. I’ve taken the planer apart and can’t see anything else thats obviously wrong.
I’m just not sure I want to throw much money at this thing, but a new planer would also take a big hit to the tool fund jar. Losing close to 10 inches on each board due to snipe is getting old now.
-Scott
-- measure twice, cut once, swear and start over.
1 reply so far
Scott C.
#1 posted 04-08-2015 01:26 PM
I’ve gotten a few emails saying there are replies to this thread but there not showing up here. Not sure why?
But to answer them, yes, Id use the cutterhead lock every time, take shallow passes, and I have checked the in feed and out feed tables, no matter where I put them I have snipe issues. Level with the bed, slightly up, up just short of jamming the machine, supporting/lifting the stock on either end. No matter what approach I get an unaceptable amount of snipe, and either way I’m still confused about why there’s two stages of snipe on the front of every board.
