jointer mulch??
« back to Coffee Lounge forum
Forum topic by MarktheWoodButcher posted 139 days ago 352 views 0 times favorited 20 replies Add to Favorites Watch
View MarktheWoodButcher's profile
MarktheWoodButcher
77 posts in 196 days
139 days ago
I can’t imagine I am the only woodworking gardener hanging out around here (“You can lead a hortaculture, but…) so has anyone else used jointer and planer shavings as garden mulch? Is there a reason I shouldn’t?
-- Knowledge Is Responsibility
View James's profile
James
161 posts in 178 days
139 days ago
I started using it for that very purpose a couple of years ago but my old man told me I was a fool because it would suck all the nutrients from your plants. Yet… I have some pretty big tomatoes already this year?
-- James, Bluffton, IN
View Hyperhutch's profile
Hyperhutch
36 posts in 147 days
139 days ago
Depends on the species I think. My next door neighbors saw me getting ready to dispose of volumes of maple lathe shavings, and they mulched their flower beds with it. So far the plants are thriving, but I think if it were walnut their soil’s nutrient balance may have gotten screwed up. From what I understand the high acidity (and possibly other factors) of certain woods isn’t so helpful.
So I would say mulch all the poplar, maple, basswood, pine, sassafrass, ash, etc… that you want. But after years of mulching oak, walnut, and exotics you might run into issues.
Of coarse, I could easily be wrong. :)
Hutch
-- I hope the volume of shavings one creates is directly related to the probablility of one's success, cuz if so I've got it made!!
View cabinetmaster's profile
cabinetmaster
8652 posts in 455 days
139 days ago
I’ve done it for years and have had no problem with it. Cedar really works good and helps keep the bugs away.
View lew's profile (online now)
lew
4497 posts in 653 days
139 days ago
As Hutch said, be careful of Walnut. I, too, have heard it is not good for plants and trees.
17007 posts in 474 days
139 days ago
I would compost it first.
View happyrobear's profile
happyrobear
1 post in 198 days
139 days ago
I thought about using my sawdust as mulch one time, but I started to worry if that might attract termites also. In my area, they can be common. Do you think that may be something to consider?
TopamaxSurvivor
3045 posts in 573 days
139 days ago
I know of a fellow who killed his garden spot for several years with wood chips. Now sure of the species, but it was probably pine in eastern WA.
20740 posts in 719 days
139 days ago
I do it all the time. I just hate having to toss it out and, since we have a heavy clay soil in our yard, it looked like a win-win situation when I started putting the shavings on the landscaped areas. I have been doing this for years now and not only is a good mulch but it also helps amend the soil.
View FlWoodRat's profile
FlWoodRat
584 posts in 806 days
139 days ago
Mark,
My last ‘major’ project (blanket chest) provided me with a significant pile of mulch. Strategic planning and a push broom and leaf blower enabled me to disperse it quite readily to the planting areas adjacent to my drive way.
Here is the pile.
-- I love the smell of sawdust in the morning....
View Gene Howe's profile
Gene Howe
334 posts in 326 days
139 days ago
I think it was in “Mother Earth News”, or a similar mag that I read that it takes more nitrogen out of the soil to break down the wood than the wood will give back to the soil. IIRC, they were talking about chips rather than sawdust.
We don’t use either around plants as our soils are nitrogen poor, to begin with.
Composting it first would probably work but, I wonder if it might slow the process???
Gene
-- Gene
View Derek Lyons's profile
Derek Lyons
266 posts in 465 days
139 days ago
I agree with the others, I’d compost it first along with your lawn waste.
-- Derek, Bremerton WA --
View mski's profile
mski
360 posts in 878 days
138 days ago
Black walnut is TOXIC to other plants so is some Cedar,
All wood dust shavings will suck the nitrogen from the soil if not composted, because the composting process uses nitrogen to compost, but if you compost first, the best free stuff you can get.
NOW that is wood NOT ply or mdf ect.
-- MARK IN BOB, So. CAL
Gene Howe
138 days ago
Mark said:
“Black walnut is TOXIC to other plants so is some Cedar,
NOW that is wood NOT ply or mdf ect.”
Some friends learned the hard way that walnut shavings are toxic to horses, as well.
-- Gene
3049 posts in 919 days
138 days ago
It’s o.k to use around garden paths but as Gene points out, it ties up a lot of nitrogen as it breaks down.
There are several studies on this if you want to google them.
View AaronK's profile
AaronK
409 posts in 362 days
138 days ago
wont adding extra fertilizer help then?
138 days ago
The last report I read suggested adding 40 lbs per 1000 lbs of sawdust.
They are talking 40 lbs of nitrogen.
The highest number fertilizer around is 46-0-0 which means 46% nitorgen ( by weight). You would need quite a bit of it. and it’s not all that cheap
Personally I just compost mine in an separate pile and use it after about 5 years to add into my usual compost pile for bulk.
For what it’s worth Trees are the most efficient store houses of Carbon on the planet.
We should try to plant trees where ever possible in our cities and towns.
View firecaster's profile
firecaster
482 posts in 316 days
138 days ago
I compost mine first. Coffee grounds have a lot of nitrogen. I pick those up from the coffee houses and put both in a plastic composter along with clippings, food waste, etc.
The sister site Garden Tenders has alot of info about composting.
-- Father of two sons. Both Eagle Scouts.
AaronK
138 days ago
wow, that’s a lot more than i expected. well, i’ve been using my shavings/chips for chicken nesting anyway!
View Chris Wright's profile
Chris Wright
360 posts in 378 days
138 days ago
Shouldn’t make any difference. My father’s composted his woodchips and sawdust for years. All different types of wood and species. It’s worked great as a compost.
-- "At its best, life is completely unpredictable." - Christopher Walken
Douglas Bordner
3427 posts in 961 days
138 days ago
I mix mine with grass clippings and then sheet compost it, turning the mixture in to about 9 inches with my tiller in the fall. Gets gobbled right up by the microbes, and is good as an amendment in pots etc. I have never had a major preponderance of walnut all at one time, but the contents of my dust collector all goes out behind the garage with the grass.
