Edge gluing: to smooth or not to smooth
« back to Joinery forum
Forum topic by IAMike posted 04-05-2015 06:35 AM 1610 views 0 times favorited 7 replies Add to Favorites Watch
View IAMike's profile
IAMike
25 posts in 1456 days
04-05-2015 06:35 AM
Topic tags/keywords: question joining
First of all, I’m fairly new to woodworking. I’m going to be making my first edge-glued panel soon, a butcher-block style top for some cabinets for my mom. They’re landry room cabinets, so the top will be made of poplar. I got 8/4 stock from my local hardwood dealer, it’s what they called “table saw ready” but the surfaces that will eventually be glued together (the long, top and bottom) are fairly rough, definitely not what you’d get from a S4S product. My dilemma is this: I don’t have a jointer or planer. That’s why I ordere the “table saw ready” (planed and straight line ripped) product. What do I need to do before I rip it and glue those edges together? Would a good sanding be adequate, or should I rent time on one of the planers or jointers at the local by-the-hour woodshops nearby? Thanks in advance for looking!
-- I'm thinking about starting a blog for my projects. It'll have to be called Woodworking By Dummies
7 replies so far
View AlaskaGuy's profile
AlaskaGuy
4053 posts in 2279 days
#1 posted 04-05-2015 08:00 AM
Never heard the term “table saw ready”. By your description it sounds like what I’d call S3S straight line ripped one edge. I really don’t know what it is by their description. They may claim “table saw ready’’ but that doesn’t necessarily mean its glue up ready. I buy all my lumber at a specialty shop that caters to the cabinet maker in the Anchorage area. Even there I rarely find S4S stock that is glue up ready. That’s why I mostly use rough cut lumber, but I do have a jointer and planer.
A good sharp glue line rip blade with leave a surface that is good enough to do glue ups.
For a successful glue up of your project it’s essential you have straight square edges that mate together without any gaps between the mating surfaces. Do not rely on clamp pressure to pull parts together that don’t mate properly. Check you stock for these qualities.
First I’d cut all you stock to and inch or two longer than you need. Now lay all the boards out on a flat surface and push then together and see how the fit. Once you see that they don’t fit together fit together proper like it’s time to go to You tube and see how to make a table saw jig to straiten one edge of each board. Once you have a straight edge on one edge you then rip the other edge on the table saw using the straighted edge against the fence. Now lay them all out again and see how the fit.
BTW it would really help if we knew how long and wide this glue up is going to be.
Also how wide is your stock. Good answers come from providing good details.
View rwe2156's profile
rwe2156
2886 posts in 1450 days
#2 posted 04-05-2015 11:16 AM
A the poster said, the edges of the two pieces need to be perfectly straight and square (or at least complimentary angles)
If you don’t have a jointer or a jointer plane, its going to be difficult, to say the least, so I would recommend using the jointer. I usually alternate faces when edge jointing just to cancel out any slight deviation from 90 degrees.
Make sure you go back and do the glue up right then or you wood may not be straight the next day!
Also, depending on where you live, if the humidity is going to be high, I would put the panels in plastic, either bags or wrapped with saran wrap to avoid warping.
As far as “table saw ready” I, too, have never heard that term, but I can assure you it doesn’t mean its perfectly straight and ready to glue up, as you can see. Even S4S isn’t ready to use.
All stock, even S4S requires some fine tuning before gluing up a panel because no matter how straight it is milled, wood moves with changes in humidity.
IAMike
#3 posted 04-05-2015 10:16 PM
Thanks for the tips, both of you. The stock is 8/4, about 8” wide and 8’ long. The final product is going to be 31” wide and 7’ long (or it could be split into two pieces fot the two cabinets it’s going to sit atop). The “table saw ready” meant that they planed it and straight line ripped one side.
AlaskaGuy
#4 posted 04-05-2015 11:27 PM
Thanks for the tips, both of you. The stock is 8/4, about 8” wide and 8 long. The final product is going to be 31” wide and 7 long (or it could be split into two pieces fot the two cabinets it s going to sit atop). The “table saw ready” meant that they planed it and straight line ripped one side.
- IAMike
https://www.youtube.com/watch?feature=player_detailpage&v=Jk7EHOQOZIQ
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1146 days
#5 posted 04-05-2015 11:36 PM
When you do your glue up alternate clamps on the bottom and top of the panel. Also use clamps at the ends of each board to keep the edges aligned (one board from moving up or down).
I start with the center most clamp and work outwards alternating the next left clamp then the next right clamp.
AlaskaGuy
#6 posted 04-06-2015 03:11 AM
- WoodNSawdust
Good advice for most clamps though not necessary with parallel clamps.
bandit571
19768 posts in 2653 days
#7 posted 04-06-2015 05:26 AM
A three board top I glued up, started out like this
With three boards folded like a map. Ran a jointer plane( see my avatar) alnog each set of edges until they were straight and even. Unfold and glue up.
