Slightly worn planer knives
Forum topic by RipFence posted 04-04-2015 07:28 PM 1132 views 0 times favorited 9 replies Add to Favorites Watch
View RipFence's profile
RipFence
77 posts in 2813 days
04-04-2015 07:28 PM
Hello All:
Thought some of you might get a kick out of seeing the knives that came out of a used planer I just bought. Ends are touching, middle is, well, not touching. It might cut better after I get these sharpened and properly set.
Jim
9 replies so far
View TheFridge's profile
TheFridge
10116 posts in 1606 days
#1 posted 04-04-2015 07:30 PM
The first planet I got had knives line that.
View bigblockyeti's profile
bigblockyeti
5206 posts in 1840 days
#2 posted 04-04-2015 08:24 PM
I’m not sure you could make good knives look that bad after flying out of the cutterhead and sticking in the nearest wall!
View WillliamMSP's profile
WillliamMSP
1084 posts in 1724 days
#3 posted 04-04-2015 08:59 PM
Those are just, uh, wide moulding knives… ;)
-- Practice makes less sucky. (Bill, Minneapolis, MN)
bigblockyeti
#4 posted 04-04-2015 10:25 PM
Another thought; So much will have to be ground off to true and sharpen them, it could be cost prohibitive and or leave too little of the blade to be usable.
View MrUnix's profile
MrUnix
6890 posts in 2318 days
#5 posted 04-04-2015 10:27 PM
I’ve found similar knives in a planer before, and have been able to straighten them out when installing in the cutter head. Start in the middle and work your way out towards the ends.
View gfadvm's profile
gfadvm
14940 posts in 2810 days
#6 posted 04-05-2015 12:28 AM
This wear pattern is a good reason to try to feed narrower stock where you are using all the blades and not just the central portion.
RipFence
#7 posted 04-05-2015 12:51 AM
Thanks! I’m sorta looking for justification to switch it to a Byrd head anyway.
Jim
- bigblockyeti
bigblockyeti
#8 posted 04-05-2015 03:50 AM
Those look pretty long (20”?), I’m guessing a Shelix head that length would cost a pretty penny.
RipFence
#9 posted 04-05-2015 01:49 PM
Sharp eye! Yep, its a 20” Powermatic 209. Those heads are interchangeable with Griz, Jet, etc so Grizzly sells em for $875.
I paid $950 for the planer, delivered to my garage. Its in excellent shape other than the knives so I think it’ll end up being a decent deal. In fact, it looks so good I was assuming that those would be the original set of knives but the writing on them indicates they have been sharpened at least once. The previous owner had a regular job and tried to run a cabinet shop after hours. He gave up after a couple of years. Given that the knives are so trashed the bearings may be a bit beat up too but I plan to change those when I switch the head anyway.
Jim
Those look pretty long (20”?), I m guessing a Shelix head that length would cost a pretty penny.
- bigblockyeti
