Ridgid R4512 TS Caster Problem
Forum topic by SawdustyDan posted 04-04-2015 12:30 PM 1486 views 0 times favorited 6 replies Add to Favorites Watch
View SawdustyDan's profile
SawdustyDan
60 posts in 1175 days
04-04-2015 12:30 PM
Topic tags/keywords: question tablesaw
As a moderately-skilled woodworker, I actually like my 4512. It does what I want it to do,to my satisfaction. However comma I do have one issue with it. Every time I move it (sometimes a few feet, somethines a few inches) the casters will release and the 200-plus-pound saw will drop to the floor. My floor is concrete and the surface (some smooth, some slightly rough) does not make a difference, nor does the direction of movement (straight front-back or side-side, at an angle, rotating, slow or fast)
I’ve looked and jiggered, but cannot see a way to adjust them, or the latching mechanism. I’ve asked Ridgid and was told there were no known problems with the casters. I’ve looked through the existing forums and elsewhere online and have not found an answer.
“Help me LumberJock Kenobi! You’re my only hope!”
-- Sawdusty Dan - Bellevue, NE - "Women and cats will do as they please. Men and dogs should just relax and get used to it." Robert A. Heinlein
View InstantSiv's profile
InstantSiv
262 posts in 1594 days
#1 posted 04-04-2015 12:51 PM
I had a 4512 for a brief time and I had that issue too. I never looked into it so I’m not going to be much help to you.
View dhazelton's profile
dhazelton
2767 posts in 2296 days
#2 posted 04-04-2015 01:10 PM
There’s some discussion of the lift mechanism not having a lock here:
http://lumberjocks.com/reviews/2536
SawdustyDan
#3 posted 04-04-2015 04:05 PM
Checked the caster installation and it’s correct. I’ve had this issue sice I got it and just put up with it. I’ve called Ridgid cutomer support to discuss the fault. The guy I spoke with hadn’t heard of this before. I’m awaiting a call back Monday, to see if anyone else knows what’s going wrong and what to do about it. Fingers crossed!
In the meantime, if anyone has any ideas, please let me know. For now, I’ve got more Stuff To Do!
View crank49's profile
crank49
4030 posts in 2970 days
#4 posted 04-04-2015 04:54 PM
I’ve asked Ridgid and was told there were no known problems with the casters..
“Help me LumberJock Kenobi! You re my only hope!”
- SawdustyDan
Exactly the problem with these POS saws.
If the damn things fried a moter every time you turned them on Ridgid’s response would be exactly the same, “We don’t know of any problems with these saws”
And it has nothing to do with your skill level.
Any problem with these saws is ignored by Ridgid. Period.
View toolie's profile
toolie
2123 posts in 2628 days
#5 posted 04-05-2015 12:18 PM
I saw a thread about this on either this or another forum. The saw’s owner had accidentally installed the caster either backwards or in some way inverted. Does it lift sufficiently off the floor for easy movement? If not, that would indicate a faulty installation.
SawdustyDan
#6 posted 04-15-2015 08:36 PM
OK, so it’s been a few days since I called Ridgid CS about this. I called back today and connected with Thecnical Support this time. Long story short – if you have a problem with one of Ridgid’s power tools, call Thecnical Support instead of Customer Support. Those folks are picked from employees who have worked assembly, testing and repair and most have a fair amount of actual user time, too.
I described the problem, she asked if I was “mechanically inclined”, and she offered to send a full caster set (newly-redisigned) directly to me. Now, I don’t have to ty to haul it off to a repair center and I’ll have the parts in about a week. All total, it took maybe 3 or 4 minutes, spent a couple minutes just yakking wth her and now I’m writing this.
I see/hear some gripes about Ridgid support and their power tools, but I, for one, am pretty satisfied with it all. I have this R4512 table saw, a TP-1300 planer and their benchtop oscilating spindle/belt sander and I’m happy with all of them!
I’ll post again, as soon as I get the caster set and install / test it out.
