how would I make these legs?
Forum topic by Deeps posted 07-08-2009 05:55 PM 1185 views 0 times favorited 9 replies Add to Favorites Watch
View Deeps's profile
Deeps
1 post in 3494 days
07-08-2009 05:55 PM
I have a client that wants a coffee table with these legs. How is that done??? Thanks in advance.
jeremy
http://common.csnstores.com/common/products/HKR/HKR3613_l.jpg
9 replies so far
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3588 days
#1 posted 07-08-2009 06:03 PM
You cut it out on the bandsaw.
117091 posts in 3575 days
#2 posted 07-08-2009 06:06 PM
Like Kolwdwrk said band saw and refine the shapes with hand or power tools.
View KayBee's profile
KayBee
1083 posts in 3244 days
#3 posted 07-08-2009 06:40 PM
Here’s a link to cutting cabriole legs to give you the idea. Shouldn’t be too hard to change it up.
http://jimnevins.net/woodworking/Fine%20Woodworking/contents/1988/110073084.pdf
-- Karen - a little bit of stupid goes a long way
View hootr's profile
hootr
183 posts in 3344 days
#4 posted 07-09-2009 11:25 AM
after you bandsaw one side use double stick tape and put it back together
turn 1/4 and repeat
that way you have some support as you saw
-- Ron, Missouri
13603 posts in 3339 days
#5 posted 07-09-2009 11:34 AM
as above , save the offcuts and use them as supports to machine sand if needs be .
it keeps the work ” square ” to blade/sander .
View rhett's profile
rhett
742 posts in 3665 days
#6 posted 07-09-2009 12:58 PM
If it is for a customer, and you actually want to turn a profit. Go to osbourne woodproducts, order four legs, make the top and skirts.
Or spent an entire week trying to make legs you’ve never built for someone who is expecting a professional result. Projects like this when done for money become business, not woodwork. Get paid for your own leg designs.
-- Doubt kills more dreams than failure.
kolwdwrkr
#7 posted 07-09-2009 05:21 PM
Rhett, good point. If it’s for a client it doesn’t make sense to make something that you can order. The time spent making them could be spent making someone elses project.
On the other hand, you have to learn sometime.
rhett
#8 posted 07-15-2009 09:29 AM
Not for nothing, but it irks me when people are still “learning” how to woodwork, yet calling themselves professional and charging a fee. How about a Dr saying, well, I am good at stitches but have never really takin out an appendix before. Sure I’ll do it, and even at a cheaper rate than Dr Appendectomy. I really want a new stethoscope.
View eastside's profile
eastside
97 posts in 3259 days
#9 posted 07-15-2009 01:59 PM
First I agree with buying them to make a profit.
Second if making them do as they said and keep the cut offs for easy band sawing.
Third it looks like the top and bottom have half rounds or something similar to that. Band saw the large sweeping curves for the basic shape and then use applied molding for the delicate stuff. This will turn the grain 90 degrees for the applied stuff and may not be acceptable.
-- Mike, Westport MA.
