Two stupid things in one week!
Forum topic by oakdust posted 07-07-2009 09:31 PM 918 views 0 times favorited 5 replies Add to Favorites Watch
View oakdust's profile
oakdust
177 posts in 3782 days
07-07-2009 09:31 PM
I was matching a color Sunday and testing it on scrap when I decided I was going to have to mix a toner and spray it on. So I got put the HVLP gun mixed the stain and poured it in the gun and noticed the pigment sitting on the bottom of the paint cup. I put the lid on shook it up and started spraying. Well it wasn’t long before the gun started to sputter and then quit spraying. I played with the adjustments and just couldn’t get it to work. Finally I gave up, tore the gun apart, cleaned it and quit for the night. As I was laying in bed still fumming over the problem I relized I mixed oil base stain with,,,,,,,Denatured Alcohol. Beleive me it dosn’t work. The other stupid thing was with the jointer. I took the blades out sharpened them with a jig I found here on LJ. Which works like a charm. Got out the dial indicator spent a couple of hours setting up and rechecking the balde alignment. I had it perfect, put the machine back together, got ready to plug it in and give it a test drive. Turend the cutter head by hand to just check it out and realized I had put all three blades in backwards. BUMMER, had to start all over.
-- Bob, Rockford IL,
5 replies so far
16274 posts in 4185 days
#1 posted 07-07-2009 09:40 PM
Ouch!
I don’t have any stupid shop stories at the moment, but I did cut the cable to my high def satellite service the other day when I confused it with an unused cable. LOL!
View PurpLev's profile
PurpLev
8534 posts in 3615 days
#2 posted 07-07-2009 10:04 PM
does this mean that you can joint boards from left to right?
at least all of those were fixable. nothing worse then measuring twice and still cutting too short on a $8bdft lumber… because you misdrew the parts layout.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3493 days
#3 posted 07-07-2009 11:52 PM
oakdust you are doing great! I have more than that each day!
oakdust
#4 posted 07-08-2009 12:25 AM
I never thought about jointing from left to right, That could have saved allot of time,LOL
TopamaxSurvivor
18248 posts in 3643 days
#5 posted 07-08-2009 04:40 AM
I hate it when that happens!! :-((
