Ash table base
Forum topic by Beauman22 posted 04-03-2015 06:35 PM 768 views 0 times favorited 3 replies Add to Favorites Watch
View Beauman22's profile
Beauman22
5 posts in 1176 days
04-03-2015 06:35 PM
Hello
I am building a farm table for a friend. The top is 8/4 white oak and after the milling and the glue up I estimate it will weigh 145 pounds. The bottom will be painted so I was going to use soft maple legs and apron but my local lumber yard doesn’t have 8/4 soft maple. I wanted to use 8/4 to avoid a sagging in the apron in the future.
I am now considering making the legs and apron out of ash and painting it. Do you foresee any problems with doing this? Or have nah better suggestions?
Thanks for any help!
3 replies so far
View bondogaposis's profile (online now)
bondogaposis
4768 posts in 2378 days
#1 posted 04-03-2015 06:47 PM
It is not the thickness of the apron that will prevent sagging but the width of the apron that is more critical. It will be fine to use 4/4 or 5/4 stock for the aprons, they should be 4 – 6” wide. For the legs, you could glue a couple of 4/4 boards together to get 8/4. Either soft maple or ash will be fine, although I think that maple will paint better.
-- Bondo Gaposis
Beauman22
#2 posted 04-03-2015 10:55 PM
- bondogaposis
Thanks for your input Bondo Gaposis. With that info I will go forward with the soft maple. The legs are going to be 4×4s. And I will either use 5/4 or 6/4 with a width of 4-6 inches like you recommended.
View Yonak's profile
Yonak
986 posts in 1548 days
#3 posted 04-04-2015 02:31 AM
Personally, I find the look of painted ash attractive. That characteristic ash grain shows through.
