Grizzly G0459 or Jet 16/32 sander
Forum topic by sawdustjunkie posted 04-03-2015 06:10 PM 1407 views 0 times favorited 4 replies Add to Favorites Watch
View sawdustjunkie's profile
sawdustjunkie
384 posts in 1741 days
04-03-2015 06:10 PM
I want to get a drum sander and have read many reviews on both of these sanders.
A co worker of mine has a G0459 that is almost brand new with probably $150 in sandpaper rolls. I can by that one for $300.
If I wait for a Jet Sale I know the Jet will be just under $1,000 before tax and extra sandpaper rolls.
Which one??
Any ideas would be appreciated
-- Steve: Franklin, WI
View Philzoel's profile
Philzoel
302 posts in 2368 days
#1 posted 04-03-2015 07:42 PM
I have the jet with input output trays and I love it I paid 1200. If the grz is any good buy it. If it does not work I am certain you can get 300 for it. Only critical dimension is flat front to back. Run two boards thru and caliper them. They should within a couple of thousands. My jet can be easily set.
-- Phil Zoeller louisville, KY
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1201 days
#2 posted 04-03-2015 07:56 PM
If the grizzly is close to new I would go with it. If you hold out for a different unit, I would suggest that you consider a larger unit. Something like the Performax 16/32 or the Jet equivalent which is available for around $1200. If you will be sanding long pieces you will want some form of infeed and outfeed tables.
sawdustjunkie
#3 posted 04-04-2015 01:09 AM
The price is good on the Grizzly, but I think will out grow it very fast. I couldn’t even sand a cutting board on the Grizzly unless it was 12” or less wide.
My local Rockler has the Jet and the Supermax 18/36. The 18/36 is a very heavy machine and looks to be made better, but it is also $1400.
View EndGrained's profile
EndGrained
24 posts in 1250 days
#4 posted 04-06-2015 12:20 AM
If you would like to read several owner’s comments, go to amazon.com. Then type in the unit you are interested in and look for ‘Comments’’.
I did this exercise earlier today while comparing a Delta with a Jet planer. It worked for me.
-- George, New Brunswick "Storms Never Last"
