How to touch up "black ash" speaker cabinets
Forum topic by groland posted 04-03-2015 04:09 PM 2498 views 0 times favorited 3 replies Add to Favorites Watch
View groland's profile
groland
212 posts in 3648 days
04-03-2015 04:09 PM
Topic tags/keywords: finish black ash
Lots of speaker companies make a “black ash” finish, which is a matte black stain over ash wood. Since ash is so light a color, scrapes in these finishes are very obvious.
Does anyone know what products to use and how best to repair/restore such finishes short of refinishing the whole cabinet?
Thanks,
George
3 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#1 posted 04-03-2015 04:41 PM
Not sure about the finish on yours, but I’ve had success hiding the scratches on similar surfaces with a black marker :)
View bondogaposis's profile
bondogaposis
5149 posts in 2587 days
#2 posted 04-03-2015 05:15 PM
Yeah, black marker for scratches.
-- Bondo Gaposis
View redSLED's profile
redSLED
790 posts in 2128 days
#3 posted 04-03-2015 05:44 PM
MORE SPECIFICALLY – A superfine-tipped black marker is the correct tool. A typical black marker tip will leave its mark on the outer edges of the scratch (which usually doesn’t wipe off) which can look like a child touched it up. Also, dried black marker touch-up can look ‘purple-ish’ against a dark black finish.
A much better touch up method:
- VERY LIGHTLY run the folded edge of a 400 grit sandpaper – into the scratch only – 3-4 times, then clean off
- open up your UNSTIRRED can of oil-based black stain and scrape from its bottom a tiny bit of its stain pigment/sludge with a very thin/pointed scrap of wood
- wipe that tiny bit of stain sludge in to your scratch, lightly remove any excess from the scratch
- carefully wipe away any excess from around the scratch edges/outer surface with a soft absorbent cloth
- then, shortly after doing the above, some guy named Bob will be your uncle
