Router bit to attach hardwood banding to plywood
« back to Joinery forum
Forum topic by PsycJester posted 04-03-2015 03:13 PM 1304 views 0 times favorited 12 replies Add to Favorites Watch
View PsycJester's profile
PsycJester
8 posts in 2020 days
04-03-2015 03:13 PM
Topic tags/keywords: router bit router bit join plywood hardwood profile glue joint table
I’m looking for a bit that aids in attaching hardwood large enough to route a profile to plywood (edge to edge). I know I’ve seen them before but I’ve spent the last week going through all my magazines with no luck. If anyone has a good lead or experience with them please let me know.
Thanks
12 replies so far
View jmartel's profile
jmartel
7882 posts in 2145 days
#1 posted 04-03-2015 03:16 PM
You can use a slot cutter bit and put a spline in, a V-groove bit, tongue and groove, etc. Lots of options.
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#2 posted 04-03-2015 03:17 PM
View timbertailor's profile
timbertailor
1594 posts in 1419 days
#3 posted 04-03-2015 03:25 PM
You could even do it with a straight bit and a slot cutter.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#4 posted 04-03-2015 03:27 PM
My favorite method is a simple tongue and groove. I cut a centered groove with a combination blade on the tablesaw (two passes), then cut a stub tenon to fit the groove. It has all the strength and alignment benefits of the other methods, and is perhaps easier to setup as well. Since the groove is centered, you will have a perfectly flush edge banding, with no trimming needed.
If you are cutting a thin edge banding, it is easier to mill the tongue on a wider board first, then rip the strip free.
PsycJester
#5 posted 04-04-2015 06:37 PM
Thanks for all the responses. The tongue and groove edge banding bits were what I was looking for. I bet I looked through 3 years of magazines. I think I may actually try the table saw first and see how that goes.
Thanks again for the help!
View dawsonbob's profile
dawsonbob
2847 posts in 1750 days
#6 posted 04-04-2015 06:44 PM
I have used these successfully.
http://www.precisionbits.com/tongue-and-groove-router-bit-set-matched-2-bit-yonico-15221.html
Hope that helps.
-- Mistakes are what pave the road to perfection
View boatz's profile
boatz
92 posts in 1646 days
#7 posted 04-05-2015 01:03 AM
I am in the process of making cabinets. I am using the Infinity tongue and groove bit set mentioned by waho6o9. Pretty slick.
-- You can't always get what you want. But if you try sometimes you just might find, you'll get what you need
View MT_Stringer's profile
MT_Stringer
3168 posts in 3226 days
#8 posted 04-05-2015 01:15 AM
What if the edge banding doesn’t line up. Whatcha gonna do then? For example, say it is a tad shy of flush. Just furious, that’s all.
boatz
#9 posted 04-05-2015 01:28 AM
I actually make the edge banding a little proud then use a flush trim bit on my router table to make it flush
View Yonak's profile
Yonak
986 posts in 1516 days
#10 posted 04-05-2015 02:46 AM
My favorite method is a simple tongue and groove. I cut a centered groove with a combination blade on the tablesaw….
- pintodeluxe
+1 .. This is my go-to method, as well.
MT_Stringer
#11 posted 04-05-2015 04:54 AM
- boatz
Me too. Only difference is I have a flush trim jig for my router, but the results are the same.
View rwe2156's profile
rwe2156
2920 posts in 1475 days
#12 posted 04-05-2015 11:23 AM
- MT_Stringer
Either start over or glue on a matching strip if you’ve no more stock.
I don’t use splines or special bits.
1. Joint the plywood.
2. Sometimes pins 1/16 proud to avoid slippage when gluing.
3. Usually use TB III (any glue works)
4. Follow with flush trim bit.
Done.
Its all edge gluing plywood anyway, guys.
I supposed if I was worried about abuse (like a stair tread) I would spline it.
