Radial Arm...router?
Forum topic by JeffP posted 04-03-2015 02:38 PM 1133 views 0 times favorited 9 replies Add to Favorites Watch
View JeffP's profile
573 posts in 1325 days
04-03-2015 02:38 PM
Topic tags/keywords: router
I was reading another current thread and this idea popped into my head.
After a little googling I find it is not a new idea, but also not a very popular one.
Here is an example of somebody who took a used RAS and replaced the saw-stuff with a router.
It seems like such a no brainer. Seems like it would be such a useful addition to a shop.
Wondering if some folks here can explain why it isn’t more common or even something that is a normal purchase at a home depot or woodcraft or harbor freight store?
Right off the top, you could use it for all kinds of dados with very easy setups.
Seems you could also rotate it to horizontal and use it for making mortises very easily.
So, why is this an uncommon “build one out of a RAS” item? Why isn’t a Radial Arm Router a “thing”?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
9 replies so far
View redSLED's profile
790 posts in 1826 days
#1 posted 04-03-2015 02:49 PM
That’s a lot of metal working to do woodworking.
View WoodNSawdust's profile
1417 posts in 1110 days
#2 posted 04-03-2015 02:51 PM
Yes it can be done. I just wonder what advantage it would have over either a hand held router or a router table?
#3 posted 04-03-2015 03:01 PM
Seems to me it would be most excellent for doing what you might call “cross cut dados”. A router table doesn’t really lend itself to dados that go across a relatively long and narrow piece.
A little more google reading suggests that many people consider this concept to be very dangerous…though I wasn’t able to determine what aspect of its operation would make it so.
View mtenterprises's profile
933 posts in 2626 days
#4 posted 04-03-2015 03:58 PM
At one time Sears offered a collet that fit their radial arm saw so you could router with it.
-- See pictures on Flickr - And visit my Facebook page -
View WhyMe's profile
998 posts in 1494 days
#5 posted 04-03-2015 09:03 PM
- mtenterprises
Yeah.. I got that crazy thing and used it a couple of times and that was it for me. Was just too fussy to mess with.
2693 posts in 1958 days
#6 posted 04-04-2015 07:07 AM
I have toyed with this idea too. Tried a quick and dirty version with a HF router and a Ryobi RAS. The arm on the Ryobi was’nt robust enough for the task. The bit wanted to wander too much. Probably runout on the router didn’t help.
Sears’ collet on their saws would only take a 1/4” bit. I agree that cross cutting dadoes would be the right use for this, but I haven’t pursued it any further.
View rwe2156's profile
2841 posts in 1414 days
#7 posted 04-04-2015 12:01 PM
There are overarm routers or pin routers similar to overhead milling machines.
As far as an RAS goes, it will never be accurate enough for precision work.
I have the attachment for mine, and have never even taken it out of the box!!
View dhazelton's profile
2722 posts in 2230 days
#8 posted 04-04-2015 01:50 PM
Seems like just making a sled of some type for the router would be easier.
You can use the old Dewalt MBF saws as shapers as the motor pivoted 90 degrees.
View MrRon's profile
4672 posts in 3177 days
#9 posted 04-04-2015 03:59 PM
The reason why RAS’s are not used as routers is because of the torque of a router at the end of an arm, it would be near impossible to keep the router from moving from side-to-side. Shopsmith had a RAS saw called the Sawsmith that could run router bits off the end of the motor at speeds up to 20,000 rpm. I had one and used it for routing, but keeping the cut going straight was not easy.
