Questions about Planers/Jointers
Forum topic by chickenhelmet posted 144 days ago 355 views 1 time favorited 16 replies Add to Favorites Watch
View chickenhelmet's profile
chickenhelmet
83 posts in 211 days
144 days ago
Topic tags/keywords: question planer jointer
I am currently looking into recycling old pallets. Great source of free lumber, but most of it is cupped. I do not have a planer or a jointer. Even used two machines don’t exactly come cheap. So, just to flaten not to edge join, which is the frist of the two one should buy. The end result I’m looking for are 2 1/2’’ X 24” strips for LP storage boxes. Thanks everyone!
-- Larry , Colorado www.coloradorecordcrates.com
View PurpLev's profile
PurpLev
2763 posts in 547 days
144 days ago
if you have a router, or a handplane or a table saw (with a jointing jig) , you can edge-joint rather easily. flattening to an even thickness however is more of a challenge and would be easier accomplished with a planer. hence – planer should be your first purchase.
View doyoulikegumwood's profile
doyoulikegumwood
278 posts in 890 days
144 days ago
i have to agree with purp their are many easy ways to joint but only one good way to plane, a planer
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View Elaine's profile
Elaine
104 posts in 521 days
144 days ago
How about a hand plane? Learn now and you’ll be able to take blade marks from the power tools off and very little if any sanding. Flea marts (swap meets) and yard sales are good places to start.
The other thing I’d look at is the cupping. Most pallets are left outside, exposed to weather. If you bring them in after taking them apart, they are now drying. Do you sticker your wood? Are you putting weight on it or tying them some how into bundles? I’ve always treated pallet wood like green wood unless my young friend needed to make a gift ASAP, meaning he should have started on it two weeks ago.
If you find an easy way to get the nails out let me know…or are you using the long skids??
-- Elaine, Conover, NC
17023 posts in 475 days
144 days ago
Well larry
I would suggest a metal detector first. Before you plane you need to have one side flat thats done on a jointer , With material of that size a jointer will do both operations both tools would be much easier.
PurpLev
144 days ago
Actually, I have to disagree with Jim on this one – a jointer will NOT do both operation if you consider planing 2 sides parallel as one of the operations – only a planer / handplaning will accomplish that. on the other hand – a planer CAN plane 1 side flat using a sled. so in essence, with a planer, and a couple of jigs (accompanied with a table saw/router) one can completely mill lumber – whereas with a jointer – you’ll always end up with 1 face that still needs to be milled parallel.
EDIT: references for you regarding flattening 1 face without a jointer:
http://lumberjocks.com/topics/1992
http://modernwoodshop.com/2008/06/18/flattening-wide-boards-with-a-planer-sled/
View DOF's profile
DOF
1 post in 143 days
143 days ago
I use a sled like that quite a bit to flatten twisted stock and I have both a joiner and a planer. Also the planer is far more portable.
chickenhelmet
143 days ago
Thanks for the replies!
PurpLev- Thanks for the clarification! Those articles are great. I think the modernwoodshop one is the ticket. So too clear it up, simple yes or no… am I to understand that just running a cuped board on each side through a joiner is NOT correct? All I do know is running boards that are not flat through the table saw seems difficult and dangerous.
PurpLev
143 days ago
running a board that does not have a straight edge against the table saw’s straight fence is dangerous and I do not know a single woodworker that would consider it acceptable. the problem is that as the nonstraight wood moves along the fence – it might (high probability) catch on the back of the blade, and kickback in your face = a quick visit to the ER in most cases.
As far as the jointer question – it’s a simple NO.
a jointer WILL flatten a face of a board. but it cannot reference the other face – which is what the planer does. so in essence if you use the jointer on 1 face, flip it and use if on the other face -you’ll have 2 FLAT faces of the board – but the likelihood of them being parallel to each other is practically zero- again – this is what the planer is for. the Planer on the other hand creates a surface that is parallel to the opposing face. the limitation here is – that if your first face is not flat – than the planer will only make a 2nd face that is not flat – but perfectly parallel to the first face. IF however the first face is flat , than the planer will create a 2nd face which is parallel and in essence – also flat.
by using a planer sled, or router sled, or hand plane to create a first flat face, you can then use the planer to create the 2nd face parallel and flat – leaving you only with the edges to worry about – which are also easily addressed with a handplane, router, or tabel saw+ jointing jig.
chickenhelmet
143 days ago
You have been VERY helpful PurpLev, thank you!
View laflaone's profile
laflaone
57 posts in 579 days
143 days ago
One of the comments made earlier by Jim is one of the most important so far, that being a metal detector first. As a retired over the road trucker, I have dealt with more pallets than I care to remember. They are full of nails, broken off nails, metal imbedded from sliding on metal floors, staples, you name it. There are some very good, and relatively inexpensive metal detectors available on a number of the common vendor sites. I do not run any, repeat any, wood thru my jointer and planer before checking for metal. I also wire brush the wood to get rid of ground in grit. My blades very rarely get a nick, and stay sharper longer. This may sound like extra work, and it is, but I consider it time well spent.
-- "non illegitimis carborundum"
chickenhelmet
143 days ago
Good point! Thanks for bringing that back up. I did put that on the list OVER the planer or jointer.
View kolwdwrkr's profile (online now)
kolwdwrkr
2252 posts in 488 days
143 days ago
I agree, metal detector and planer.
View GaryK's profile
GaryK
9537 posts in 886 days
143 days ago
Planer is all you really need as stated above.
The method Purplev posted is a method I came up with for long pieces.
I use the other method all the time for shorter pieces that are more than the 6” width of my jointer.
And as stated a Metal Detector.
chickenhelmet
142 days ago
Thanks everybody! Metal detector and planer it is (for now). I’m sure there will be a “need” jointer sooner or later.
View hairy's profile
hairy
296 posts in 430 days
142 days ago
Nice hat! I got one of these last month for $13, it’s definitely ok for $13.
http://www.woodcraft.com/product.aspx?ProductID=142012&FamilyID=3820
-- I'm a lumberjock and I'm ok, I sleep all night and I work all day!
View aurora's profile
aurora
38 posts in 150 days
142 days ago
i seconds jim’s recommendation, .... but you really need all 3 machines or you’ll drive yourself crazy. #1 get a metal detector, #2 get a jointer, you need to flatten your wood first with jointer on 2 sides, table saw the third edge parallel to the first jointed side, then plane it to make the 4th side parallel to the second side . if you have minimal boards to do then metal detector and hand plane and table saw.
