Refinishing teak dining table
Forum topic by jon345 posted 04-03-2015 01:40 PM 1016 views 0 times favorited 5 replies Add to Favorites Watch
View jon345's profile
jon345
1 post in 1177 days
04-03-2015 01:40 PM
Topic tags/keywords: teak danish
I’m planning to refinish a teak dining table and could use some tips on products and technique. As you can see – this tabletop has some fading on the main section along with some minor staining. My goal is to remove the stains and get it so the main section is a similar tone to the leaves, then finish with something durable (my kids will beat on this) such as General Finishes Arm-R-Seal, which I’ve used in the past with good success. Some questions:
- Do I need to strip or can I just go straight to sanding? If strip, any particular product?
- When sanding, what grits should I use?
- Any recommendations for finish other than Arm-R-Seal? Goal is durability and low maintenance while bringing out the natural beauty of the teak.
5 replies so far
View pjones46's profile
pjones46
1001 posts in 2669 days
#1 posted 04-05-2015 11:13 PM
Is solid teak or teak veneer?
-- Respectfully, Paul
View OSU55's profile
OSU55
1701 posts in 2016 days
#2 posted 04-06-2015 12:14 AM
Depends on what the original finish is and is it a film finish. An unknown fil finish should be stripped either chemically or sanding scraping.
View Aj2's profile
Aj2
1440 posts in 1825 days
#3 posted 04-06-2015 12:30 AM
Looks like teak plywood with a solid wood edgeing,If you try to sand it most likely you with burn thru at the edges.So be careful.If it has a finish on it now it maybe better than anything you can get?
-- Aj
View bondogaposis's profile
bondogaposis
4767 posts in 2378 days
#4 posted 04-06-2015 01:37 AM
I’ve had really good results with Behlens rock hard table top varnish.
-- Bondo Gaposis
pjones46
#5 posted 04-06-2015 03:37 AM
+1 to Aj2
Assuming it is a teak veneer, most I have had experience with are very thin veneers so care must be taken not to burn through. The color/finish discrepancy between the pull out extensions and the main table is partly due to light exposure as well as cleaners used on the table.
Getting the color/shade to match is going to be the biggest problem where you may have to tint the finish to obtain an acceptable balance.
As far as a finish, there are many choices, but I use Zar Poly in one form or another. You also could use a wipe on poly, however, it would take many more applications to get the finish to build.
