Twisted Drawer
Forum topic by danriffle posted 139 days ago 184 views 0 times favorited 7 replies Add to Favorites Watch
View danriffle's profile
danriffle
37 posts in 467 days
139 days ago
I dry assembled a long skinny drawer (about 21”x 7”x 2 1/2”) and it has a twist from corner to corner of almost 1/4”!
Any sly tricks out there to get these joints to behave?
Thanks,
Dan in WV
View Sean's profile
Sean
83 posts in 509 days
139 days ago
1/4 ” is a bit. is the face of the drawer attached to the sides, or are you applying the face piece after? if so, i’d just plane the high corners….if it was a bit smaller of a twist, i would suggest taping sandpaper to a flat surface and just moving the drawer back and forth over it until it was flat. obviously if the face is already attached to the sides, an integral part, these ideas won’t work because you’ll have too large a reveal on the drawer.
-- "Democracy is by far the worst system of government. Except all the others that have been tried." ~ Winston Churchill
16696 posts in 471 days
139 days ago
You might be able to take it apart and spray it were the twist is with hot water and clamp it to a flat surface and let sit over night.
View Bruce's profile
Bruce
91 posts in 668 days
139 days ago
Wut kind of wood is it? Wut kind of joints?
Bruce
139 days ago
Start by taking it apart and checking each and every piece that it is perfectly square and equal dimension to the plan, or its opposite side/piece.
View Kjuly's profile
Kjuly
84 posts in 179 days
139 days ago
You say it was dry assembled…
You did the right thing in dry assembly. I would do as Bruce said and check each part.
If you do not find the problem there then reassemble the drawer making sure you do not over clamp. A drawer 2 1/2” high can be twisted pretty easily by over tightening the clamps.
Keith
-- Keith, Charlotte, MI www.julyswoodworks.com www.TheBenchDawg.com
TopamaxSurvivor
3014 posts in 569 days
139 days ago
reassemble a piece at a time to discover the offending joint, hopefully not offendiing jointS!
danriffle
139 days ago
Thanks for all the replies.
The joints are an odd variety—cove & pin. Sort of dovetail like in function, but different in form. Which is why I was looking for general advise on taming twist.
I’ll definitely disassemble and reassemble a piece at a time to locate where it’s misbehaving.
