Padauk Question
« back to Woodturning forum
Forum topic by Charlie75 posted 04-02-2015 03:53 PM 813 views 0 times favorited 4 replies Add to Favorites Watch
View Charlie75's profile
Charlie75
312 posts in 2227 days
04-02-2015 03:53 PM
I have a piece of Padauk that I will be incorporating into a bowl that I am going to be turning. When I pick this piece of lumber up it feels kind of like a sticky substance on the surfaces. It’s not a heavy sticky thing but just feels different then maple or walnut etc.
Will this be a concern when I finish the bowl? I have never used this material before so I am unfamiliar with it.
Charlie
-- Charlie75, Alto
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1139 days
#1 posted 04-03-2015 04:09 PM
Try cleaning the surface with solvent before gluing or finishing.
View Ron Ford's profile
Ron Ford
208 posts in 1695 days
#2 posted 04-05-2015 10:08 PM
+1 for WoodNSawdust’s answer. You should be fine after wiping it down with lacquer thinner or even denatured alcohol.
I like padauk and use it in a lot of woodturning projects. It has wonderful color and grain. Two points I’ll make for you: -If you are using it next to a very light wood (like holly) be aware that it will ‘bleed’ while sanding, especially if you are power sanding on the lathe, and;
-Paduak is UV-sensitive and will bleach out to a less vibrant brown after exposure to sunlight. Think about using a UV-resistant finish if it will be placed in an area exposed to sunlight.
Hope this helps.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
View Woodknack's profile
Woodknack
11475 posts in 2342 days
#3 posted 04-06-2015 04:23 AM
If you sand, be prepared for red dust that sticks to everything. If at all possible, prefinish light color wood next to it.
View oldnovice's profile
oldnovice
6755 posts in 3330 days
#4 posted 04-06-2015 04:59 AM
After sanding your shop will look like a RUST storm hit it … use a dust collector.
I use it a lot for accent on my projects.
