Pocket hole joinery question
Forum topic by Allen posted 08-30-2007 06:23 PM 1335 views 0 times favorited 6 replies Add to Favorites Watch
View Allen's profile
Allen
43 posts in 4065 days
08-30-2007 06:23 PM
I’ve been looking and darned if I can find the answer to this question, so I’m turning to the experts…
I have a Kreg R3 pocket hole jig (the one with the sliders on the sides to adjust for the thickness of the material).
If I’m joining two pieces of wood that are not the same thickness, one piece is 3/4” the other is 1/2”, do I use the setting on the jig and select the screw size based on the thicker board or the thinner one?
If it makes any difference, the pocket hole will be drilled into the thicker board.
I would assume I’d use the setting on the jig for the thicker board so that the hole is centered on the edge but should I use a screw made for the thickness of the thinner board? If I use a screw for 3/4” thick material I’m afraid I’ll end up driving it straight through the thinner piece.
Thanks as always for suggestions!
-- We may never know who let the dogs out, but I'd bet anything PETA was involved.
View RobS's profile
RobS
1334 posts in 4300 days
#1 posted 08-30-2007 06:29 PM
Not that I know the answer you are looking for, but I think it would be important to know how you want the two boards to line up. Center to center, so there is a lip, or step down on each side? Or will the faces be flush on one side, with the big lip on the opposite side?
-- Rob (A) Waxahachie,TX
View spoon's profile
spoon
5 posts in 3916 days
#2 posted 08-30-2007 06:56 PM
I think you are on the right track with centering the hole on the end thing. If I were worried about a screw poking through I would cut the tip off. Make sure start the hole with a good screw, then switch it out.
—spoon
-- --Spoon
View mot's profile
mot
4911 posts in 4030 days
#3 posted 08-30-2007 07:15 PM
Use a 1” screw and put the pocket in the 3/4” board with the 3/4” setting. Use a test piece first though, just in case.
Cheers!
35120 posts in 4394 days
#4 posted 08-30-2007 09:31 PM
Yes you use the screw size that is tailored for the thinner board.
View Thos. Angle's profile
Thos. Angle
4444 posts in 3956 days
#5 posted 08-31-2007 03:59 AM
Listen to Karson and Tom.
dennis mitchell
3994 posts in 4308 days
#6 posted 08-31-2007 06:49 PM
I’m thinking forget the screw thingy and go with double sided sticky tape!
