motor wiring help
Forum topic by 6288 posted 07-05-2009 06:33 AM 1031 views 0 times favorited 6 replies Add to Favorites Watch
View 6288's profile
6288
4 posts in 3272 days
07-05-2009 06:33 AM
i just inherited an older table saw. Motor is missing plate. How do I tell if it is a single or 3 phase motor? Plug is three pronged 250/125. Thanks for any help you can offer.
TopamaxSurvivor
18286 posts in 3700 days
#1 posted 07-05-2009 09:58 AM
One of the prongs on the plug should be a ground. probably single phase. A 3 pahse motor will have a connection box on the side that will usually have 9 wires in it. could be only 3 or as many as 12, but usually 9. They will be connected together to 3 leads coming out. If its single phase the cord will usually go to a small connectioin box that is flush on the end of the motor.
View 6288's profile
6288
#2 posted 07-05-2009 08:34 PM
thanks. the motor has 6 wired coming out if it. it is wired to a three wired (B,W, G) 250 plug. The wired coming in is grounded green to the motor. the on off switch has three termanils and says on the side
TopamaxSurvivor
#3 posted 07-05-2009 10:57 PM
It should be a single phase motor. The green should be the ground. I can’t of a reason for a 3 phase motor to bring out 6, you couldn’t change the voltage for the motor.
TopamaxSurvivor
#4 posted 07-05-2009 11:33 PM
Suppose I’d better correct that statement ;-)) The new drive rated motors do bring out 6 wires on 3 phase motors, but the old ones don’t.
View 6288's profile
6288
#5 posted 07-06-2009 02:00 AM
so a single phase you can change voltage, 3 phase you can’t?
TopamaxSurvivor
#6 posted 07-06-2009 02:23 AM
You need 9 wires to change a 3 phase from high to low or vice versa. I don’t remember exactly what the connections are for single phase. Never did enough of them. Some are dual voltage and some are reversible when the proper wires are brought out to the connection box.
