stupid workbench question
Forum topic by CharlesA posted 04-01-2015 02:16 PM 1184 views 0 times favorited 10 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3361 posts in 2038 days
04-01-2015 02:16 PM
Topic tags/keywords: question
I have a sturdy, homemade SYP workbench. I have not taken time to put in drawers because I want to take time to make things I like. So, I have a simple shelf that works pretty well, except for one thing: sawdust, shavings, and chips go through the dog holes and get over everything on the shelf. With my improved dust collection, the only surface covered with sawdust, etc. are the items on my shelf.
Absent building in drawers, anybody else had this problem and developed a solution?
10 replies so far
View crank49's profile
crank49
4032 posts in 3211 days
#1 posted 04-01-2015 03:47 PM
That’s why some benches are designed with drawers and shelves in an enclosed cabinet and have a space between the cabinet and the bench top. That space is for clamps and also to store sawdust.
I could see that space being easy to hook up to the dust collector and then the dog holes would function like a floor sweep. Have something you want to get rid of just sweep it to a dog hole.
Smitty_Cabinetshop
15822 posts in 2859 days
#2 posted 04-01-2015 03:54 PM
That s why some benches are designed with drawers and shelves in an enclosed cabinet and have a space between the cabinet and the bench top. That space is for clamps and also to store sawdust.
- crank49
Crank speaks truth. Move the shelf up by putting drawers under it, and you’re still collecting sawdust, shavings, etc.
View TheDane's profile
TheDane
5576 posts in 3903 days
#3 posted 04-01-2015 04:10 PM
Nothing stupid about the question … that’s why I built my bench with a separate cabinet …
Click for details
Every so often I just hit with compressed air then vacuum up the shavings and dust.
View BroncoBrian's profile
BroncoBrian
875 posts in 2199 days
#4 posted 04-01-2015 04:36 PM
Great bench Gerry.
How did you drill your holes and make sure they were spot on, it is very important to make sure they are square, right? Also, do the holes go through the top workspace?
-- A severed foot is the ultimate stocking stuffer.
TheDane
#5 posted 04-01-2015 05:40 PM
I drew a matrix on the top with a framing square. I used a drill guide and started them with a Forstner bit (to get a clean shoulder), then drilled through with an auger-style bit. I clamped a piece of plywood to the underside to minimize blowout.
View DIYaholic's profile
DIYaholic
19752 posts in 2915 days
#6 posted 04-01-2015 06:47 PM
What about a masonite or 1/8” ply “shelf/drawer” that would slide out. It would collect the dust, then just slide out and clean it off. Kinda like a “crumb tray” for/on a toaster oven….
May seem like a lot of work…. compared to Gerry’s solution!!!
CharlesA
#7 posted 04-01-2015 06:57 PM
Thanks everyone for all the responses. For a long time I was storing a log of items on the floor under the table, so I didn’t want to install a large cabinet with drawers/doors. I don’t do that anymore, so I may end up with a cabinet down there at some point. I also wanted adequate clamping surface.
I’m not going to do a cabinet anytime soon, so I may go for the sheet of plywood an inch or so under the top. that seems easy and helpful.
View Richard's profile
Richard
1922 posts in 2931 days
#8 posted 04-01-2015 07:04 PM
May seem like a lot of work…. compared to Gerry s solution!!!
- DIYaholic
Now that is a good idea to me, just slde it out and Vac or Blow it off. The Vac may be better so you don’t get everything else covered in dust.
crank49
#9 posted 04-01-2015 08:57 PM
crumb tray for a toster; perfect analogy
View moke's profile
moke
1283 posts in 3016 days
#10 posted 04-02-2015 05:40 PM
Iwould make sure your crumb tray will come out….what if you want to use a hold-fast?
Mike
-- Mike
