Unparallel Dewalt 733 thickness planer!
Forum topic by Mark Shymanski posted 147 days ago 343 views 1 time favorited 5 replies Add to Favorites Watch
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 611 days
147 days ago
Topic tags/keywords: thickness planer out of square repair
Hello All,
Finally got some shop time so thought I would try out my new Leigh Super Jig. First step is to dimension some wood. Fine, I get my 5 test pieces lined up joint ‘em and then run them through the planer to dimension them. One side is dead on 3/4 ” the other about 1/8 or so narrower. I was a bit annoyed, as I’d never measured this carefully before and have probably had this major difference since I bought the used Dewalt.
Well I had to change to sharp blades anyway…and I figured how hard could it be to remedy the unparallelness anyway. Sometimes ignorance really is bliss LOL! I pulled the cover off quickly swapped the blades out (I downloaded the manual from the Dewalt website…Thank you Dewalt!). The manual does not describe how to true up the squareness of the machine. So I look at it for a bit and fiddle around and notice the threaded rods on both sides that raise and lower the cutting head. They measure about 2 mm off (the distance from the deck to the frame of the cutter head). On top of one of them is of course the crank, on the opposite side is a wee disc with a set screw in it. I undo the set screw fiddle a bit with the cutter head measure both sides and voila it it back in true. Well I’ve not run wood through it yet but I had to come in and make the kids lunch and thought I’d quickly blog about this. Is blog a verb or a noun? Any way I am very pleased with how well this worked so far and really appreciate how well written and illustrated the manual was and how easy it was to take apart.. and more importantly rebuild the 733.
Well got to get the kids fed, type at you folks later :-)
View rickf16's profile
rickf16
224 posts in 480 days
147 days ago
I’ve got the 733 also. Never thought about it getting out of “whack”. Thanks for the info. Will check mine next time I use it.
-- Rick
Mark Shymanski
147 days ago
If you do need to square it up, I could probably give a more detailed description, but once you open the cover it is pretty straightforward.
View marcfromny's profile
marcfromny
11 posts in 258 days
142 days ago
oh no! I better save this thread. I think I may need new blades or get them sharpened, but I thought they just popped bakc into place. yikes. I hate truing things up!
-- http://www.woodworkerspost.com/Forum/
25806 posts in 1299 days
142 days ago
Nice find and help for others.
Mark Shymanski
142 days ago
Thanks Karson, I’ve received so much from this site it is nice to be able to return a modicum of it.
marcfromny the blades did just pop right back into place if you use the magnetic jigs Dewalt supplies (they are mounted on top of the blade cover…see the manual). It was dead easy to get the blades back in, the lack of sqaureness had nothing to do to with the blades but actually the frame that holds the motor and blade assembly.
