Help! Dust collector pipe collapsed
« back to LumberJocks.com Site Feedback forum
Forum topic by RlPorsche posted 221 days ago 355 views 0 times favorited 7 replies Add to Favorites Watch
View RlPorsche's profile
RlPorsche
2 posts in 221 days
221 days ago
Topic tags/keywords: dust collector
Just hooked up my new dust collector & about 15’ of the 8” metal pipe collapsed flat. I used HVAC standard ga. Due to price & viability over spiral. I had a 6” opening in the pipe while running drum sander with 4” connection, it was getting every little spec then wham. Three sections of pipe collapsed flat. I realized this HVAC pipe dis-connects by pushing in on the seam, my current thought is to use 12” plywood squares with 8” holes in them, then place then every so often so the pipe can’t distort then collapse, screw the seams to the plywood with a “L” tab plus tape the seams. This is a lot of work for an untried idea, any suggestions?
Thanks
Dick, & Barb Cain
7210 posts in 1270 days
221 days ago
You must have a powerful DC. What size is it?
3317 posts in 312 days
221 days ago
you might open the line somewhere a little ,
as your 4” is choking the 6” .
and the suction is building up .
View MedicKen's profile
MedicKen
655 posts in 433 days
221 days ago
Standard HVAC pipe is NOT recommended for dust collection systems because of the thin wall thickness. It can, and as you have experinced, collapse.
View Greg's profile
Greg
380 posts in 279 days
221 days ago
If you want to use metal pipe you should use spiral pipe that is made for dust collection. HVAC pipe …as you found out…is no good for dust collection. It is for Heating Ventilation Air Conditioning, which does not have anywhere near the pressure rating as dust collection requires. You can also use schedule 40 PVC pipe which is far better than HVAC. Several woodworking supply companies sell adapters that allow you to connect it to standard 4” dust port tool fittings.
There is a lot of info out there about the numerous options of dust collection options.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. Have a nice day, unless you have other plans!
View PurpLev's profile
PurpLev
3440 posts in 619 days
221 days ago
HVAC pipe is not heavy duty enough to handle air pressure of DC – as you’ve obviously noticed.
suggestion? since you have some of the layout already made – go with the spiral metal ducting that is made for DC. OR, go with ASTM 2927 PVC – it’s thiner than Schedule 40 PVC, lighter, but can withstand the high pressure of DC. however I’m not sure is it’s available in 8” diameter… it is in 6” and 4”.
what DC are you using?
View ND2ELK's profile (online now)
ND2ELK
7442 posts in 745 days
221 days ago
I used metal duct work from Penn State and it works great. Look at my layout and you can see how it turned out. Good luck!
God Bless
tom
-- Mc Bridge Cabinets, Iowa
RlPorsche
2 posts in 221 days
220 days ago
Thanks for the input, my idea worked great!! I am running 45’ of 8” , 3/ 90s, 1/8”X6”X6” combo, 1/8”X6”X6” combo, 30’ of 6” , 2/90s 1/^”combo., 3/6”X4” reducers, 3’ of 4” ABS 4/1/4 bends and 20’ 4” flex with 5’ 0f 2” flex for a vacuum line with a total rise of 20’. My vacuum line works better than a new shop vac. With my drum-sander & planner line open, I need to make some blast gates.
After seeing the efficacy rating of spiral, the size available in PVC, ABS, cost of laser welded stainless what I have works well so far and is (I used almost no screws through my pipe) rated the same as laser welded pipe
