Cambered, toothed, regular plane blade what are there specific purpose?
« back to Hand Tools forum
Forum topic by DavidL41 posted 03-31-2015 04:53 PM 829 views 0 times favorited 3 replies Add to Favorites Watch
View DavidL41's profile
DavidL41
11 posts in 1068 days
03-31-2015 04:53 PM
What are the differences of a cambered blade, toothed blade and regular blade?
Cambered blade – What is the reason someone would use a cambered blade over a regular blade? Is this for removing more material easily when the blade is lowered, removing edge marks from wood or both? do smoothers, jointers, jack planes scrub planes all benefit from a cambered edge (I usually see these on scrub planes,jointer planes, jack planes but not smoothing planes)
toothed blade – I don’t know too much about this type of blade. It seems like its a very specific blade made for exotic woods. What situation would a toothed blade be used other than exotic woods? Would toothed planes be used for removing large amounts of material roughly?
3 replies so far
View ElChe's profile
ElChe
630 posts in 1244 days
#1 posted 03-31-2015 05:25 PM
I use a slightly cambered iron for smoothing to prevent the lines that show up when smoothing a board. A more heavily cambered iron can be used for taking bigger cuts on a board like scrubbing a board but I don’t do that because I prefer a slight camber on basically all my irons. A toothed iron works well with highly figured woods as it reduces tear out. You won’t see the nice curlies like with a cambered smoothing plane or a regular plane. You end up with chips more than curly shavings. But it does reduce tear out even with a low angle bevel up plane like the Veritas. A regular iron, flat across the edge, I don’t use but I think you could probably use it for all planing functions although you will end up with the lines and will need to clean those up with a card scraper or sanding. This is not the gospel truth. Just my approach to planing by the way. :)
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1122 days
#2 posted 03-31-2015 05:50 PM
I slightly camber my ploane blades so that I can plane the field of a board without digging lines into it. As elche said the deep pcamber can be used with or across the grain for aggressive stock removal. I use a thickness planer and a jointer to establish flat stock, so I stay away from the deep camber. Toothed irons are specifically for wild grain, but I’ve never met a grain so wild that I couldn’t work it by simply raising the iron and changing the angle of approach, so I’ve never owned or used a toothed iron.
I have one iron that I keep dead flat along the edge, that is my shoulder plane.
-- Talent, brilliance, and humility are my virtues.
View shipwright's profile
shipwright
7895 posts in 2705 days
#3 posted 03-31-2015 11:03 PM
Toothed irons are also used to “true” a surface before veneering and to provide a better tooth for adhering the veneer.
When using sawn veneers it may also be necessary to true the face of the veneer itself. A toothing plane will immediately show up any low spots.
