Circle Cutting on a Bandsaw?
Forum topic by DavidinSpain posted 07-03-2009 12:46 AM 879 views 0 times favorited 4 replies Add to Favorites Watch
View DavidinSpain's profile
DavidinSpain
2 posts in 3465 days
07-03-2009 12:46 AM
Hi All. I have had an enforced break from woodworking for a few years but I am back!! I seem to have managed to get all my machinery working. The bandsaw circle cutting jig , I made years ago, was lent out and never came back. There’s a moral there somewhere!!!!!.
I have made a new jig but something is not right.
I need to make some 2” wheels/discs but the blade snatches and I can’t seem to sort it.
I have marked a line on the jig at right angles with the front of the blade and on this line I have put a pivot pin.
The jig is clamped to the table so no lead in, is this correct ?
I have tried a 1/8 blade and a 1/4 blade.
Any tips or help will be gratefully received.
Thanks
David in Spain
View lew's profile
lew
12017 posts in 3719 days
#1 posted 07-03-2009 01:22 AM
I am just asking here but does the jig base extend past the blade- to the “waste” side of the cut? I think there should be some support under the work piece on both sides of the blade.
DavidinSpain
#2 posted 07-03-2009 09:31 AM
Hi lew
The jig is the full size of the bandsaw table so plenty of support.
Thanks
D
13600 posts in 3305 days
#3 posted 07-03-2009 03:18 PM
maybe you have a blade “drift ” problem ,
the blade may be favoring 1 side or the other ,
and making it wander and bind .
see the woodwisperer vidio about this ,
or move your jig a little to aproach the blade at a diferent angle slightly .
View lew's profile
lew
#4 posted 07-03-2009 03:49 PM
Did you try roughing out the wheel blank slightly larger than the diameter you need and then re-cutting it using the jig. Even though you are using a narrow blade, it could be binding on such a small diameter piece.
