Advice for attic refinish ceiling
Forum topic by kcrandy posted 07-02-2009 09:56 PM 1317 views 0 times favorited 6 replies Add to Favorites Watch
View kcrandy's profile
kcrandy
285 posts in 3633 days
07-02-2009 09:56 PM
Topic tags/keywords: attic remodelling
I have a nice attic space I want to refinish about 14’ x 12’ which is under the pitched roof, i.e. an A-Frame type space. A couple of questions. The roof is clay tile. I have inuslated between the rafters and am now contemplating what to use to finish the ceiling. I’m lookin at tongue and groove pine, either eastern knotty white or yellow. I can get lengths up to 14’ so won’t have seams. Any recommendations on what pine to use or suggestions for other materials?
I’m also unclear on whether I should sheeth first or nail the tongue and groove slats into the rafters. I’ve heard that clay tiles roofs should breathe, but have I already messed that up with insulation. On the other hand, I hate to have no insulation since the space needs to be heated and cooled for habitation.
Advice appreciated and thanking you for it.
-- Caulk and paint are a poor carpenter's best friends
TopamaxSurvivor
18390 posts in 3877 days
#1 posted 07-03-2009 10:03 AM
All enclosed spaces need to breathe. the price is dry rot if they don’t.
View Julian's profile
Julian
880 posts in 3727 days
#2 posted 07-03-2009 04:16 PM
You better make sure to use baffles between the roof sheathing and the insulation, unless you want it to rot. There needs to be airflow between the insulation and sheathing!
After you fix your first mistake, then you can either sheet the ceiling first or just put the tng boards right on the rafters.
-- Julian, Park Forest, IL
117328 posts in 3778 days
#3 posted 07-03-2009 05:29 PM
I’m with Julian you need some baffling and eave vents. If you sheath it you will have more to nail to.
A good place to look for building answers is Finehombuilding .com I still us it after 20 years as a contractor.
kcrandy
#4 posted 07-06-2009 04:55 PM
I’ve just learned from my roof person that we can get vents that look like clay tile but provide venting system for 100 square feet of roof area. So I’ll be able to provide proper air flow from the roof itself instead of underneath. www.ohaginvent.com provides these special pieces.
View Grandpaw's profile
Grandpaw
21 posts in 3500 days
#5 posted 07-06-2009 05:58 PM
why would you want them to look like cray tile?
-- Carving
TopamaxSurvivor
#6 posted 07-06-2009 08:59 PM
The roof vents still need a source of air, like holes along the eves and the insulation not blocking by being tight against the roof. Most roofs and attics are under vented. If you put in twice what they recommend you’ll be ok. We had a 50 yr metal roof put on that was supposed to be vented at the ridge. When I saw the size of the holes for air flow, I made them open up my old roof vents too.
