Waxing MDF Cross Cut Sled?
Forum topic by tommyc325 posted 03-31-2015 03:56 AM 2718 views 0 times favorited 9 replies Add to Favorites Watch
View tommyc325's profile
tommyc325
59 posts in 1558 days
03-31-2015 03:56 AM
Topic tags/keywords: jig question
Hi Everyone
I have a Cross cut sled that Im not happy with the “action” in pushing back and forth. It works fine but not as smooth as I would like it to be. Im figuring I can add some paste wax to the bottom of the sled and the runners but I wasn’t sure if you can apply paste wax to MDF.
Cross Cut Sled:
3/4” MDF Base (Its what I had laying around.)
Plastic Runners
Any suggestions would be appreciated.
9 replies so far
View TimberMagic's profile
TimberMagic
114 posts in 1381 days
#1 posted 03-31-2015 04:10 AM
I made an MDF top for a workbench, CNC-milled with 20 mm holes to work like Festool’s MFT workbench. For a little protection, I applied some butcher block finish I had, which is a blend of mineral oil and wax. It left a nice smooth finish. You might want to give that a try. It was easily applied with a rag, and then just wiped well. The picture of it is on “My Workshop” page.
I specifically did not use straight wax since I didn’t want the mess of it needing to be wiped out of all the holes. A sled base would certainly be easier to apply and wipe off. Maybe try both on a scrap piece of MDF and see what you think works best.
-- Lee
View FirehouseWoodworking's profile
722 posts in 3475 days
#2 posted 03-31-2015 04:11 AM
Not sure how well the wax would work given that the MDF will soak up a lot of the wax. Wax may even cause some cupping which would ruin the sled.
Instead, you might want to think about putting a piece of laminate (e.g., Formica) on the bottom with contact cement. Just remove the runners, glue on the laminate, then reinstall the runners. The last step would be to seal the top and edges of the sled to keep moisture from causing any cupping. I used spray lacquer on mine and it remains flat after all these years.
Just a recommendation . . .
Cheers!
-- Dave; Lansing, Kansas
View Mykos's profile
Mykos
103 posts in 1996 days
#3 posted 03-31-2015 04:16 AM
Yes. I put paste wax on the bottom of an MDF router sled and it worked just fine.
View ElChe's profile
ElChe
630 posts in 1538 days
#4 posted 03-31-2015 04:24 AM
Wax the table saw top and the miter slots. Seal the MDF and wax it as well.
View pjones46's profile
pjones46
1001 posts in 2845 days
#5 posted 03-31-2015 04:26 AM
Apply the paste wax that does not contain silicones to the table top of saws, bandsaws and router tables as well as the MDF. As it wears you will have to reapply every so often.
-- Respectfully, Paul
View rwe2156's profile
rwe2156
3171 posts in 1683 days
#6 posted 03-31-2015 11:19 AM
I sealed mine first with boiled linseed oil (50/50 mix with turpentine) then a couple coats of shellac.
You could also use polyurethane or acrylic, but I had the shellac laying around so I used it.
It’s not as durable.
If you use BLO, give it a couple days to dry before sealing.
I waxed the bottom only once never had to do it again seems to work fine.
View Mike Gager's profile
Mike Gager
665 posts in 3469 days
#7 posted 03-31-2015 11:39 AM
johnsons paste wax works great for me. wax the top of the saw too
View Jim Finn's profile
Jim Finn
2687 posts in 3124 days
#8 posted 03-31-2015 12:57 PM
- Mike Gager
What they said. I use Johnsons paste wax on my MDF jigs.
-- No PHD just a DD214 Website> craftingcouple.com
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2571 days
#9 posted 03-31-2015 01:45 PM
- Mike Gager
Another supporter of this. I use Johnson’s paste wax on my jigs, and all of my tool tables. I’m not as religious as I should be in my upkeep of it, but it’s painfully obvious when I’ve let things go too long between waxing.
