Table Saw a Cabinet Virgin. Looking at General vs Shop Fox.
Forum topic by Little_Woodworking posted 03-31-2015 02:33 AM 3320 views 0 times favorited 17 replies Add to Favorites Watch
View Little_Woodworking's profile
Little_Woodworking
7 posts in 1480 days
03-31-2015 02:33 AM
Topic tags/keywords: question tablesaw shop fox grizzly general craftex cabinet saw
I also posted this on sawmillcreek. just for an FYI
Looking at getting either a General International 50-275RC30 (which I seem unable to find any reviews of ($1,799)) or a Shop Fox w1819 ($1841.90 shipped) (amazon.ca) which is the Grizzly 690.
What I have now is a Bosch jobsite Saw GTS1031 . it works okay but with what I do, the fence is too small, the table in front of the blade is too short, Rip Capacity is always too small. The finish on it likes to rub off. The plastic ZC inserts flex and make ripping thin stock almost pointless unless you love gouges and burn marks. Its a hard start 5000 rpm and the thin kerf blades always flexed on start up chewing up the zero clearance.
What I do. well I am mostly a toy/model builder. I also build furniture, boxes, urns, sculptures and other woodworking projects. I need a fence that stays true, a blade that stays true no matter where I raise or lower it. easy adjustment of the riving knife or blade guard. I can just cut a 8 inch wide then rip half a dozen 1/8 strips. My current saw you have to take the insert off raise it all the way up, use a wrench to unlock as the finger lever (plastic) broke off after 2 weeks and never was able to get a replacement. sawdust gets in there and moves the riving knife slightly causing problems. so I just never use the guards. actually the guards on the Bosch are flimsy and have caused more danger then prevented.
Reasons for the General well the dealer is 1 hr drive away (on sale right now for $1500). can not seem to find any reviews except for comments from 2010 to buy the 350 which I wish I could as it was Canadian Made. I will be in Thursday to get medication and will have a look in person. 1 year warranty I also own the industrial 14 inch bandsaw that has done a lot of work, and General Mortiser not as much work as I was hoping.
Reasons for the Shop Fox lots of reviews, easy to remove/change the riving knife, lots of potential addons. I might want to add on to cut capacity later. the w1820 is $1100 more for a 50” instead of a 30 which seems crazy to me. Craftex sells the same saw as the cx201 and the 50 is the same price as the Shop Fox 30 but too wide for my current shop and that is before shipping. 2 year warranty on the shop fox
Reason for not buying used. I always have had bad luck buying used. I do not look constantly but when I do see them on Kijiji its a 5hr round trip just to look at it given their size and my arthritis I need one or two people to go with me, or they have been in a storage shed for… years and rusted covered top. or and almost always not a cabinet saw.
I have looked at getting a saw stop but $2000 vs $4600. anything will be safer then my current saw.
Business is really picking up here and I do not have time to spend tinkering with an oldie ( though I wish I did would love some table saw you needed a drive belt and a stationary engine for)
-- "as a carpenter would or a shoemaker, if meeting in either of their shops with some shavings, or small remnants of their work, thou shouldest blame them for it?" Meditations Marcus Aurelius
17 replies so far
View pjones46's profile
pjones46
1001 posts in 2844 days
#1 posted 03-31-2015 03:22 AM
IMHO, for what it is worth, all of the saws are made offshore and many are exactly the same under the hood with cosmetic changes requested by the so called onshore manufacture. That being said, service and replacement parts are more important should you have a problem vs the brand name.
Research the reviews to determine the problems, then go from there.
-- Respectfully, Paul
View Minorhero's profile
Minorhero
373 posts in 2807 days
#2 posted 03-31-2015 08:25 AM
The base model is the 50-275R. Try searching for that and you should have some better luck with reviews. For my money I would go with the general simply because it has a cast iron plinth while near as I can tell the shopfox has sheet metal. I am a big believer in more metal being better. Also because its apparently cheaper.
View knotscott's profile
knotscott
8148 posts in 3577 days
#3 posted 03-31-2015 09:35 AM
The Canadian made “General” 350 and 650 are no longer available, and were among the very best saws made…. General “International” is not the same, so don’t let General’s reputation sway you blindly. Both lines were owned by the same Canadian family.
From a glance of the schematic in the manual, the W1820/G0690/CX200 appear to have more robust under pinnings than the 50-275. The 50-275 has nearly identical guts to the Powermatic PM64B hybrid style contractor saw…the biggest difference being the size of the motor. The 50-275 also has an aluminum fence rail. The GI 50-270 is built more like the W182O et al. It’d be best to see them all in person, and go with whichever floats your boat. I’d be inclined to go with the more proven SF, Craftex, or G0690 just out of familiarity.
You can add about 10 rip capacity to any of the saws you mentioned pretty easily.
GI50-275:
PM64B:
Compared the pics above to these: G0690 (W1820/CX201):
GI50-270:
View rwe2156's profile
rwe2156
3171 posts in 1682 days
#4 posted 03-31-2015 10:42 AM
Although a 3HP cabinet saw may be more saw than you need for what you’re doing, times, ideas, and demands change, so if one’s thinking is to have more capacity in a machine today than you may need because you don’t know what tomorrow will bring, then you can’t go wrong with either machine.
Have you looked at a hybrid saw? This one is on sale now for $775 with shipping.
Bottom line: If you can afford it, go for it. You’ll never be limited by your saw.
You will have a nicer table saw than alot of ww’ers doing much bigger jobs.
View poospleasures's profile
poospleasures
776 posts in 2686 days
#5 posted 03-31-2015 11:25 AM
I have owned three Shop Fox tools for over at least two years each. I could not be happier with the performance from each one. The 1819 saw is easily adjusted and holds the adjustments perfectly, has plenty power for all species of wood. It has the 30” rails and has ample room to mount a router in the RH wing which fits real well in my small shop space. When I bought it from Amazon on sale it was delivered to my shop for less than 1300$. Have changed the belts one time about a year ago. The 1706 bandsaw w/riser block is also a well made work horse in my shop and with a Woodslicer blade will consistently cut very thin slices needing little sanding. The other great Shop Fox tool is the 1676 6X48” belt w/ 10” disc sander. These are the most used tools (more than once daily ) tools in my shop. I am an old woodworker and would advise buying Shop Fox for any of these three. However be advised there is other tools of this brand which do not deserve such good remarks .
-- I,ve had amnesia for as long as I can remember. Vernon
Little_Woodworking
#6 posted 03-31-2015 03:44 PM
- Minorhero
I have tried so many combinations and variations on what to search and how and still could not find anything.
knotscott
#7 posted 03-31-2015 04:20 PM
- Minorhero
- Little_Woodworking
It’s not much, but here’s a blurb from Woodshop News:
http://woodshopnews.com/tools-machines/tools-a-machines-archives/502218-general-offers-beefed-up-cabinet-saw
There’s also some spec info on the hingmy.com site:
https://www.hingmy.com/site/content.php?p=4204
Little_Woodworking
#8 posted 03-31-2015 05:26 PM
I just read that the 50-275r is just a 3hp version of the 50-200r which there is a lot of talk about in comparison.
200r does get a lot of comparison to a hybrid saw.
pjones46
#9 posted 03-31-2015 07:03 PM
Look at Grizzly G0690 and for it to go on sale or look for a coupon.
View jdh122's profile
jdh122
1052 posts in 3019 days
#10 posted 03-31-2015 07:08 PM
I have the General International 50-200r and am very happy with it. No doubt 3 hp is better than 2, but I’ve not managed to bog the motor down yet.
-- Jeremy, in the Acadian forests
Little_Woodworking
#11 posted 03-31-2015 07:22 PM
- pjones46
Unfortunately the grizzly is going to be $200 more then the shop fox even before the additional shipping costs to Canada.
It seems like my saw takes more and more time to get things rightly set up. Having a table saw that sometimes runs several hours a day. having it stay true is becoming more and more of a necessity then a luxury. I have lots of higher priced items being ordered and looking at one job and the saw is pretty much payed for. This is something I should of looked at more when things were a little slower after Christmas. Now it almost feels like pressured to get a good saw and get back to work. as I keep pushing the limits of my saw in almost every aspect.
knotscott
#12 posted 03-31-2015 08:44 PM
- pjones46
The parts lists look to be interchangeable between the two saws. Shop Fox trunnion parts are all numerically 100 more than the Grizzly counterpart.
http://pics.woodstockint.com/partslists/w1820_pl.pdf
http://cdn0.grizzly.com/partslists/g0690_pl.pdf
pjones46
#13 posted 03-31-2015 09:18 PM
Shopfox is owned by Grizzly so may be the exact same items under different names. I bought my G0690 on sale for $1,325.00 plus $150 freight and at that time the Shopfox was more money.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3433 days
#14 posted 03-31-2015 09:30 PM
I have been happy with my 1023RLW.
Little_Woodworking
#15 posted 03-31-2015 10:07 PM
Well I will still check out the General on Thursday but I have a feeling I will go with the Shop Fox.
Thank you everyone for the opinions and personal experiences.
