Question for the wise ones of woodworking?
Forum topic by Workbench_Warrior posted 06-30-2009 10:57 PM 1011 views 0 times favorited 9 replies Add to Favorites Watch
View Workbench_Warrior's profile
Workbench_Warrior
47 posts in 3253 days
06-30-2009 10:57 PM
Topic tags/keywords: question
Has anyone seen or built a box to enclose the motor on a contractor saw for dust control purposes? I know you can cut a panel to fit the opening with cutouts and I have seen a cloth cover advertised but they still let a lot of air in decreasing the suction of the central dust vac. I was thinking that maybe a box enclosing the motor might work well but not sure anyone have any thoughts of wisdom on this subject? Sort of making it into a cabinet saw base I guess!
-- SAEPE EXPERTUS, SEMPER FIDELIS, FRATRES AETERNI - "Often Tested, Always Faithful, Brothers Forever"
9 replies so far
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3584 days
#1 posted 06-30-2009 11:05 PM
you will need to watch that the motor gets air to keep cool.This is very imoportant it might burn out the motor ,stall it during a cut,or even start a fire I would not do this seek advice from the manufacturer but I would beware of this idea sorry.If the box is as large as a cabinet thats a different matter I would still advise a few grills to allow circulation Good luck Alistair
Workbench_Warrior
#2 posted 06-30-2009 11:11 PM
Thanks for your thoughts Alistair. I’m not doing it just considering options, I have a panel on the back right now but looking for a better solution. (especially when I forget to remove it before tilting the saw) I thought that heat or even sawdust might be a factor but I figured they enclose cabinet saws. What is different about them?
13603 posts in 3340 days
#3 posted 06-30-2009 11:13 PM
alistair is right ,
keep it cool!
put in vents ,
close to motor ,
and suction away from motor area .
View skeeter's profile
skeeter
233 posts in 3340 days
#4 posted 06-30-2009 11:14 PM
The last issue of fine woodworking had an entire article devoted to it. The article.
-- My philosophy: Somewhere between Norm and Roy
Workbench_Warrior
#5 posted 06-30-2009 11:23 PM
Thanks Skeeter, trouble is you have to sign up and pay to read the article but it looks like it is boxed in.
117091 posts in 3576 days
#6 posted 07-01-2009 01:05 AM
Hey Joe
You can sign up for a 14 day free trail it really covers what your asking about very well.
skeeter
#7 posted 07-01-2009 01:25 AM
you don’t get Fw? It is the best IMHO. Though I’m sure someone will shoot me down with Woodworker Mag.
View BigJimAK's profile
BigJimAK
30 posts in 3290 days
#8 posted 07-01-2009 06:12 AM
Joe,
Only enclose it if you are using a dust collector. If so, seal up the rest and let the air come in around the blade and onto the motor (i.e. carefully placed vents).
Jim
-- Jim in Alaska
Workbench_Warrior
#9 posted 07-01-2009 06:20 PM
Thanks everyone and Skeeter I use to subscribe to all of the Woodworking mags and many others but now that I’m retired the budget is not there any more lol. But I did sign up for the online one I guess I can cancel it later if I don’t use it much. I downloaded the PDF and I think it is exactly what I’m looking for so thanks Oh Wise one; you get the crown for today anyway lol. I knew there was a good reason for joining LJs!
