Blade drifting down on Table Saw
Forum topic by KAnderson30 posted 03-29-2015 10:57 PM 1428 views 0 times favorited 10 replies Add to Favorites Watch
View KAnderson30's profile
KAnderson30
2 posts in 1029 days
03-29-2015 10:57 PM
Hi fellow woodworkers. I am a new poster to lumberjocks. I was looking for some feedback and came across this great site. However, I couldn’t find any info about the problem I am having.
I have a pretty cheap tablesaw. Its the mobile porter cable table saw. I think pcb222ts something like that.
Anyway my problem is I was trying to cut half laps using my single blade (Dont have a dado set) using my crosscut sled and noticed how much the depth of cut changed throughout. My guess is the vibration of the saw and weight of the motor move the blade down.
Has anyone had this problem on cheaper saws? And any solutions to fix this? A way to lock the depth adjustment in place?
Thanks for the help.
10 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2564 days
#1 posted 03-30-2015 01:08 AM
My first tablesaw was a cheap Ryobi and I had the same problem until someone here told me to RAISE the blade to the required height rather than LOWERING it to the required height. Don’t ask me to explain why, but it stopped my blade lowering problem!
View MrRon's profile
MrRon
4566 posts in 3118 days
#2 posted 03-30-2015 11:28 PM
When you lower rather than raise the blade, the backlash in the screw adjusting mechanism allows the blade to drop due to it’s own weight and vibration. This is true for any saw, from a cheap table saw to an expensive cabinet saw.
View jeffswildwood's profile
jeffswildwood
2721 posts in 1851 days
#3 posted 03-31-2015 12:01 AM
Glad you posted this. I just tried half laps on a box and had the same problem. Thanks for the advice guys. I have a very basic skil table saw.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View splatman's profile
splatman
586 posts in 1273 days
#4 posted 04-01-2015 03:37 AM
I ran into the same issue years ago. And I figured out the ‘only raise to the mark’ trick. When lowering the blade to a new level, I over-lower it, then raise it.
View pjones46's profile
pjones46
997 posts in 2517 days
#5 posted 04-01-2015 05:15 AM
Let us know if it corrected your problem.
-- Respectfully, Paul
KAnderson30
#6 posted 04-01-2015 11:36 AM
Thanks for all the replies everyone! I haven’t had a chance to try it out yet but you all are in agreement so my hopes are high that this will fix my problem.
View rwe2156's profile
rwe2156
2749 posts in 1355 days
#7 posted 04-01-2015 11:37 AM
When you lower rather than raise the blade, the backlash in the screw adjusting mechanism allows the blade to drop due to it s own weight and vibration. This is true for any saw, from a cheap table saw to an expensive cabinet saw.
- MrRon
I’ve never experienced this with my Jet cabinet saw.
View Tony1212's profile
Tony1212
151 posts in 1609 days
#8 posted 04-01-2015 03:14 PM
I don’t have have a cheap table saw, but I do have an old table saw that I inherited from my grandfather that lacks the height lock function.
In my case, raising the blade to the required height does help but it does not solve my issue. My blade still drifts down during the series of cuts. It became readily apparent when I was making cabinet rails and styles with a groove for the panel and my stub tenons didn’t fit the later cuts.
I’ve read and found that some people use clamps and vice grip type pliers to hold it in place. I plan on building a cabinet and using a rod clamp like you might see in a laboratory holding a beaker over a flame to hold the shaft of my height adjustment in place.
My grandfather didn’t spend much time cleaning the saw, so when I got it the worm drive was coated in sticky saw dust (most likely due to the pine resin since everything he made was out of pine). I suspect that helped prevent the drift, but it was nearly impossible to turn the hand wheel. Now it turns well, but it won’t stay in place.
-- Tony, SW Chicago Suburbs
rwe2156
#9 posted 04-01-2015 03:48 PM
Sounds like a Craigslist unload and a new saw are in your future!
13594 posts in 3215 days
#10 posted 04-01-2015 04:01 PM
have had that prob at times
with various saws
make a wedge
to stide behind the crank
as stated raise the blade to the height you want
tap the wedge in with s hammer lightly
should keep the crank handle from spinning
