| Forum topic by Rustic | posted 1417 days ago | 1873 views | 0 times favorited | 3 replies | ![]() |
1417 days ago |
Has anyone ever used Titebond cold press glue for wood veneer? Would appreciate any advice on using this stuff. -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
3 replies so far
#1 posted 1417 days ago |
Titebond III and Cold Press are two different products – III is an exterior “waterproof” glue, and Cold Press is a veneer glue (maybe also for built up laminating? – not sure). I use the Cold Press all the time and have no problems with it. I leave it in the Roarockit bag for 2 hours and it’s good to go. I have some panels out in the garage for an aquarium stand that I never finished. They’ve been out there for 18 months through St. Louis heat, humidity, below zero temps, etc. and look the same as they did when I put them in. The only advice I would offer is to do a test first to get a feeling for how thin to spread it – a little goes a long way. I put it on the substrate and then use a 1” brush to spread it around. Also, don’t forget to put wax paper between the veneer and cauls/bag so you don’t have to worry about squeeze out sticking. -- Steve, Webster Groves, MO |
#2 posted 1417 days ago |
My bad it was the cold press for veneer. Not titebond III -- www.carvingandturningsbyrick.com, Rick Kruse, Grand Rapids, MI |
#3 posted 1417 days ago |
I have used Titebond cold press with good results. I use a foam brush for spreading it evenly. And like Steve said… don’t forget the wax paper on top, because some glue will bleed through the veneer. -- Charlie M. "Woodworking - patience = firewood" |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15746 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
