I'm not particularly fond of pocket hole joinery
« back to Joinery forum
Forum topic by jtm posted 03-29-2015 08:04 PM 1087 views 0 times favorited 4 replies Add to Favorites Watch
View jtm's profile
226 posts in 1568 days
03-29-2015 08:04 PM
I decided to build a shop cabinet last night.
I was debating between pocket screws or dados.
I figured “Kreg jiggin’ it” would be quick and easy, but just like every other time, getting perfectly aligned joints was just an exercise in frustration. I even went out to buy the $30 right-angle clamp.
I’ve read all the tips and tricks to preventing the joint from creeping when tightening the screw, but half of them are at the expense of the efficiency and simplicity that pocket joinery is supposed to provide.
Dado joints would’ve been faster, and the damn cabinet wouldn’t be out of square by 1/8” either.
Just sayin’
View waho6o9's profile
8130 posts in 2509 days
#1 posted 03-29-2015 08:12 PM
What type of material were you using?
View jtm's profile
#2 posted 03-29-2015 08:28 PM
- waho6o9
8/4 ebony with 1” koa face frames…
3/4 birch ply
View SamuraiSaw's profile
515 posts in 1896 days
#3 posted 03-29-2015 08:30 PM
I only use pocket holes for face frame, too much trouble and effort for box construction. As you know, dados are far more accurate and efficient.
-- Artisan Woodworks of Texas....
View pmayer's profile
1021 posts in 2997 days
#4 posted 03-30-2015 02:16 AM
Like SamuraiSaw, I mainly use pocket screws for face frames. I much prefer dado joints on the carcase. I believe that they are quicker and stronger than screws for carcase construction. I would actually use biscuits before pocket screws on carcase construction.
For face frames, however, pocket screws joinery is the bomb.
-- PaulMayer,
