Split rocker leg from dowel
« back to Joinery forum
Forum topic by jonsprague0000 posted 03-28-2015 11:51 PM 963 views 0 times favorited 6 replies Add to Favorites Watch
View jonsprague0000's profile
jonsprague0000
104 posts in 1589 days
03-28-2015 11:51 PM
Topic tags/keywords: split wood crack crack dowel maloof rocker chair walnut repair epoxy
I’m building a maloof rocker and when attaching the arms with a dowel I split the top of the front leg. I’m using a 3 inch long 1/2 dowel to connect the bottom of the arm to the top of the front leg. It was a tight fit so I hit it with a mallet and then noticed 2 splits on either side.
What can I do to fix this or minimize any further splitting. It’s glued in now so I won’t be able to pull it apart.
View gfadvm's profile
gfadvm
14940 posts in 2690 days
#1 posted 03-29-2015 12:23 AM
Filling that split with epoxy is probably your best option (short of making a new leg). Use a good quality (like West Systems) and not the 5 minute stuff from HD.
runswithscissors
2752 posts in 2025 days
#2 posted 03-29-2015 01:14 AM
It should be possible, with a very thin, fine toothed saw, to saw that joint apart. Then drill out the dowel from both pieces, epoxy the cracks and clamp together, then try again with a better fitting dowel. Dowels not only are not precision machined, they also can swell from humid conditions. I’ve even made repairs where the dowel was (intentionally) significantly smaller than the hole, and filled the void with thickened epoxy. Gives you lots of flexibility in positioning the joined parts.
The saw should be able to make a 1/32” kerf, which will be unnoticeable, but will leave some scratches on the arm to sand out. Being underneath the arm, they won’t show too much anyhow.
Actually, I have no problem with the 5 minute epoxy. Mix it with a little walnut dust from your sander to improve the strength and coloration.
gfadvm
#3 posted 03-29-2015 02:02 AM
My issue with the 5 minute epoxy that comes in those double syringe thingys is that they don’t ever dispense equal parts of materiel like they are supposed to. Then it may take forever to cure or even remain slightly soft which creates problems when you go to sand it.
runswithscissors
#4 posted 03-29-2015 07:40 AM
I never buy epoxy that way. A decent hardware store or hobby store should have it in 4 oz. (I think) bottles). Those little dispenser gizmos are for people who don’t know how to squeeze out equal amounts of stuff. If you have curing problems, it’s probably because the mix is off. Epoxies all have their specified mis ratios, but often 50-50. You don’t want to hurry things up with extra hardener. Has the opposite effect, and may not cure properly (epoxy doesn’t “dry”, which is solvent evaporating, but it cures, which is a chemical reaction. Though 5 minute stuff will set within 5 minutes, it needs an hour or 2 to get really hard.
jonsprague0000
#5 posted 04-01-2015 01:49 PM
I like the idea of cutting the arm out and completely fixing the mistake, but I’m afraid that I may cause more damage.
Would it make more sense to only fill with epoxy or to cut walnut wedges and put them in the crack. That way I could fill it with solid wood.
View Gene Howe's profile
Gene Howe
10479 posts in 3428 days
#6 posted 04-01-2015 02:08 PM
A mixture of walnut dust and epoxy would be my fix. You’d be surprised at how well it will blend.
BTW,
