Large Oval Frame - How To?!
Forum topic by pashley posted 06-29-2009 03:02 PM 5251 views 0 times favorited 7 replies Add to Favorites Watch
View pashley's profile
pashley
1043 posts in 3683 days
06-29-2009 03:02 PM
Topic tags/keywords: oval
Now I’ve gone and stepped in it!
A friend commissioned me to do a large oval frame – about 2’ x 3’ – for a an art project.
“Sure” I said, “I can do that”.
Never done it! However, I think I know how to do it. You have to basically glue up four or six pieces of stock in an equilateral shape, and then route / bandsaw / jigsaw out the shape.
Is that right? What kind of joint to use? Finger? Biscuit?
I know I can buy or make a jig to draw out a perfect oval.
If you know of any articles out there detailing this, please let me know!
-- Have a blessed day! http://newmissionworkshop.com
7 replies so far
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3492 days
#1 posted 06-29-2009 03:47 PM
The Charles Neil dvd on routers shows you step by step on how to make any oval or round frame and he makes look real easy.
View lew's profile
lew
12018 posts in 3721 days
#2 posted 06-29-2009 03:49 PM
Here is a site to show you how to draw an oval:
http://www.waterfront-woods.com/Articles/Ellipse/stringellipse.htm
Somewhere I saw a mechanical device that does this, too. It was made from a block of wood and had a couple of sliders attached to an arm- which held the pencil. Someone here probably has an example of that device.
View Greg Wurst's profile
Greg Wurst
794 posts in 3798 days
#3 posted 06-29-2009 03:58 PM
More oval drawing advice:
http://www.woodweb.com/knowledge_base/How_to_Draw_an_Oval.html
As for construction, you’re looking at a lot of end-to-end gluing which is weak. If the frame dimensions allow it I’d use pocket holes. Biscuits might work as well, but don’t add much strength.
View CaptainSkully's profile
CaptainSkully
1590 posts in 3524 days
#4 posted 06-29-2009 06:23 PM
You can do an ellipse (oval) with two nails, a string and a pencil. Tie the ends of the strings to the nails and use the pencil to form a triangle. As you slide the pencil through the 360 degrees, keeping the string tight, it will form the oval. You control the dimensions of the oval with the distance the nails are apart and the length of the string.
Also, I recommend using splines on the joints. It’s the only method that’s strong enough for the small surface area. Make sure the stock you glue up will be wide enough to encompass the entire oval (i.e. wide and narrow sides), both inside and out. To make the second oval, you can either do a series of offsets from the original oval or change the length of the string.
Good luck. If we never move out of our comfort zone, we never grow. Please post your progress.
-- You can't control the wind, but you can trim your sails
View lew's profile
lew
#5 posted 06-30-2009 01:56 AM
Here is a link to the jig I mentioned above:
http://www.popularwoodworking.com/article/OvalLayoutJig/
117063 posts in 3542 days
#6 posted 06-30-2009 04:16 AM
Lots of good information. I’ve used spline,sadle joints and halflap Joints and finger joints.
pashley
#7 posted 08-16-2009 07:27 PM
I’m still looking for ideas for this. I was able to make a jib that will draw out an oval nicely. Now, I have the hardiboard cut out for the artist to draw on. I just need to make the frame now – and that’s where I am perplexed. To boot, it has to be made out of 3” wide birdseye maple!
It seems like what I have to do is make a pentagon or hexagon shape, and then cut out the oval from there. Of course, this mean rather wide stock, I’m guessing around 5 inches or so, using finger joints or biscuits. Man, did I bite off more than I can chew! Can anyone help?!
