Lubricating a cabinet saw arbor mechanism
Forum topic by JillB posted 06-28-2009 11:41 AM 2069 views 0 times favorited 4 replies Add to Favorites Watch
View JillB's profile
JillB
8 posts in 3300 days
06-28-2009 11:41 AM
I have a 10inch cabinet saw ( like the older Delta units), and I would like to lubricate the sliding bearing of the arbor mechanism shown in the attached photos. Can anyone advise the best way to do this, as I cannot locate any grease nipples.
I was thinking of applying a dry lubricant, like CRC Dry Glide, but don’t know if this would be suitable for this type of bearing and the weight associated with it.
The other problem is making sure that all the bearing mating surfaces are covered with the dry lubricant, but this is difficult as there are some sections of the bearings that are never exposed, unless you dismantle the whole arbor :(
You can see the arbor mechanism with the bearings indicated here
A close up of the front arbor bearing is shown here
I would welcome any informed comments and expert technical opinions , please
regards,
Jill
View Splinterman's profile
Splinterman
23074 posts in 3355 days
#1 posted 06-28-2009 01:33 PM
Try using a large medical seringe filled with powdered graphite….....it will penetrate right down the slides.
View John Gray's profile
John Gray
2370 posts in 3880 days
#2 posted 06-28-2009 01:39 PM
I’ve used CRC Dry Glide on my table saw adyustment screws with great success.
View budmitch1's profile
budmitch1
8 posts in 3392 days
#3 posted 06-28-2009 08:39 PM
I’ve had good luck using LPS Dry Moly Lubricant. It sprays on and runs into the slides then dries. Sawdust won’t stick to it once dry
JillB
#4 posted 06-29-2009 06:54 AM
Thanks everyone, I feel a lot more confident using Dry Glide on the trunnion bearings now
regards,
Jill
